Tire pressure...?
#41
Look into the Continental Extreme Contact DWS. They are cheaper than the OEM tire... Tirerack, has the OEM Pilot HX MXM4 at $258/tire in the stock size, but the Extreme Contact DWS at $119/tire for the stock size.
The DWS are also orders of magnitude better than the OE tire in every category. I just got the DWS installed on my 19" rims, and couldn't be none the happier. They seem to be even better than the Bridgestone Potenza RE960AS Pole Positions I ran before.... (And the DWS is an Ultra High Performance All/Season tire)
Well, the only problem with them is, they are always out of stock on tirerack and my local tire shops and I'm not really looking or want an UHP tire. I want a smooth ride and ultra quiet noise level tire and am looking more at Grand Touring. I have Serenity's on there now and want to replace them with another Grand Touring. Problem is, the only one left for a good price kumhos, though the load rating is higher than OEM specs, but if you read my other post, something is wrong with my front-end with alignment issues and I have to get that fixed by Acura before I put any new set of tires on the car or they will suffert the same fate as my current Serenity's!
#42
#43
As far as being out of stock, I just got mine installed like 2 weeks ago, so they should be in stock by now, as I remember America's Tire Company telling me they were getting new stock at the end of this month.
#44
Please tell me where I've said this.
Where did I say that? Did you miss this quote of mine in post#24:
Get a life and while you're at it, try to brush up on your reading comprehension skills....
#45
The DWS are actually very quiet tires. If you look at the reviews on Tire-rack, people are saying the same thing... They are definately quieter than the stock tires that came with the TL, and those stock tires were Grand Touring tires as well... Plus the stock tires were damn scary to drive in the rain with....
#46
Huh? I brought that up because the reference to "different construction" in that paragraph clearly refers to radial vs bias ply, not a/s vs summer. The manual is saying use radial vice bias ply. It's not saying that you have to use a/s over summer tires. Remember, our TLs come with an option for summer tires when you buy new?
You said all of this in the other thread, some in this thread, don't act like you don't know what I'm talking about. You have a lot to learn now quit shitting in this thread and start another if you want to argue.
#47
I also doubt Continental is going to modify the tire design.. .They are taking so long because the tires were supposedly on national back order. But when I was calling around, stock seemed to be trickling in, as the warehouse in California and Georgia both got shipments of stock a few weeks ago, when I was looking for the tires...
By the way, do you run dedicated winters? Just curious, becuase my G coupe came with Pilot Sport Summer Tires... Those tires grip like ice cubes when it gets below 50 degrees, especially if the pavement is damp... That's why I swapped those out for Pilot Sport All/Season, becuase I kept fishtailing at damn near every traffic signal when making a turn with that car when it was below 50 and damp.... A forum member allegedly talked to tire rack, and they said that summer tires should only be used when ambient daytime temps are > 60 degrees and ambient night temps are > 50 degrees.
#48
Come on, I'm waiting...
But you won't because you can't...Sure you'll come on here and spew accusations and then slink away...
Come on big fella, back up your words with proof of my comments...
Wait, I'll make it easier for you. Here's the link to the other thread:
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/psi-issue-776614/
Go there and pull up where I've said anything you accused me of saying.
Oh, what's that? No proof?...Oops, guess you're wrong again!!
#49
Huh? The important part of that paragraph was "use the same size and construction". When turbonut alluded that construction meant you had to stick with a/s vice summer, I pointed out that construction means radial vs bias play, not a/s vs summer and that summer tires are still acceptable per OEM specs.
You're so full of sh!t...If I said any of what you quoted, then prove it. Come on, go pull up the quotes where I've said any of those things you're accusing me of. Come on, show everyone how good you are. Show them where I've said any of that.
https://acurazine.com/forums/showthread.php?t=776614
#50
I'm not in a big hurry. My local Sears currently has some quality techs (ex-military) that I trust and they'll match tirerack's (or anyone's price) after shipping. Of course, they can only get their supply from their main warehouse, which in turn, relies on Continental warehouse.
Only this winter did I use dedicated snow tires. Made a huge difference in snow. The rest of the time, it's been a/s tires year round. Yes, it's true that summer tires perform better on hotter surfaces. Personally, I wouldn't have any issues using summer tires year round as long as the ambient temperatures stayed above freezing (and no snow/ice). That doesn't happen here in ND! The summer tire compounds get very hard at or below freezing and lose traction. Tirerack was probably implying that you could only expect the full performance from summer tires at the higher temperatures...
#51
Keep Right Except to Pass
Apparently having someone answer a question you asked must have offended you, based on your reply (quoted above at the start of this comment). I thought your "freakin [sic] simple question" was so simple that it wasn't interesting enough to address and so I replied to the one I found more interesting. If you don't want a question answered, don't ask it!
#52
Well then, it should be so easy for you to prove yourself. Go on, show everyone where I said anything you've accused me of.
Hehe, just like I said, you can't back up your accusations....Come on, it's not too late, you can still do it..
Oh, damn, that's right, you can't....But I already told you that in my previous post and you just confirmed it for everyone. Thank you!
#53
#54
I don't care to get another thread locked. If it were worth arguing about, or if you could carry a technical discussion I would put more effort into it. Everything is in the link so if someone actually cares to hear about it they can read and see that I'm right. If they don't care, they aren't forced to read more of your BS in this thread. The best thing you could do for yourself is to quit posting and learn something... And I'm not talking about articles that you pick and choose on the internet. Get out there and actually try something in real life instead of repeating bad information. I run 2 sizes wider, higher load rating, higher pressure, much, much stickier ultra performance tire on the TL and bias ply wrinkle walls on the GN and never have I had a tire issue yet you insist because you read stuff written by lawyers that you're right. Amusing.
What's the matter BIG MAN, can't find anything to back your accusations?
Oh come on, please, pretty please? Just show everyone where I said those things. It'd be so simple, if only you could. But you havn't and you won't, because you can't.
#55
Before you answer you had better look into the situation, and you'll find it's a no go.
#56
I found your other question more interesting, and nobody had answered it. You asked this:
I answered that question:
So no, you didn't answer the question. Stop being as smart ass with your remarks as well. I have every right to ask the question you! Get off your high horse! If you had answered the question, instead of quoting me useless information on your 2004 TL, which doesn't help me at all since my recommended pressure is different, you have to get all pissy about it! I didn't ask what is recommended tire pressure, I asked if it is okay to put the same air pressure in all four tires and not stagger it like it shows! That was the question, which you didn't answer!
#57
Once aging that is your interprutation, so I'll ask about putting 2 A/S tires and 2 Summer tires on the car. As you consider them both the same, it should present no problems with handling characteristics? Right?
The manual (not me, just reproducing what is said in the manual) clearly defines "Summer" and "A/S" as different "TYPES" of tire (pg 220):
"Tire Types
All Models Except 6-Speed with
Summer Tires
Your vehicle is equipped with high
(marked All Season or M + S on the
sidewalls). These tires provide
excellent handling and braking
performance in most driving
situations.
6-Speed with Summer Tires
These tires have a high-traction
compound and tread pattern to
provide superior acceleration,
cornering, and stopping under
most driving conditions.
I think you're saying that summer and a/s are of different construction (I assume you are saying your definition of "construction" includes tire compounds)...and I'm not saying you're wrong....just a different definition than what I think the manual uses for "construction".
I was trying to say that in the paragraph where the manual references construction, it is referring that the construction be radial, not bias ply. The type of radial could either be A/S or Summer (or winter or snow).
#58
There was another thread about tire pressure where someone said that the reason for the different PSI between front and rear had to do with the handling characteristics of front wheel drive (and it may have been only referring to 6MT, can't remember). I don't remember if that statement was validated with a reference or not. If that's true, then you may notice a difference in handling if you use the same pressure all around. I doubt that it would be dangerous but can't say for sure.
You have an unfortunate situation with your steering/front end. Personally, I don't think adjusting tire pressure will help your situation. I hope you can get Acura to step up and fix your steering/front end. Have you filed a case with ACS yet?
#59
Still running your mouth I see. You're good at that. Once again, you still haven't backed up your accusations. Nice job trying to misdirect and cover up the fact that you cant back up your accusations.
It's you who can't back up a single thing you're said. You ignore every post I make about tire size, type, load rating, etc. and post worthless quotes taken out of context. You know better than to have a technical argument with me because you will get your ass handed to you. I can back up everything I say because I've run every type of tire in real life under street and racing conditions. I feel like a retard arguing with someone of your intelligence and experience level. Until you get out from behind the computer and try things for real in real life, you have absolutely no credibility.
You want to start a thread and call me out, go for it, I would love to hand you your ass. You've gotten enough threads closed due to your ignorance, so until then
#60
No you didn't answer the question. Instead of answering whether its okay to keep the tire pressure the same all around, you quoted me the recommended pressures or a car I don't have, it had a different transmission, a different year, which had different mag wheels, etc all of which makes a difference since the recommended you quoted me is different from the recommended on my 08's door sill!
Yes, it's perfectly fine to run the same psi all the way around. The fronts tend to create more heat due to more weight and pressure will rise a little more from cold to hot. By the time they reach full temp, they should be very close to even all the way around if you go with the manufacturers specs on the OEM tires.
You've got a good +- 5psi safety cushion, probably more, before you run into any issues with wear, comfort, or heat. Don't put too much thought into it unless you're going to the track.
I set mine up to be about even once fully hot. This means running a little less in the fronts when cold. My car will get around the track the quickest this way.
#61
is how I feel that you two have now shit up another thread.
Either:
(1) Learn to ignore each other and not respond to each other or
(2) Have a civil conversation without the condescending tone, name calling and confrontational style post.
This is now a warning. Next time a mod has to deal with either of your BS, your gone.
Either:
CostcoFanAUS
09-18-2015 06:05 AM
