Tire Pressure?????
Old 05-27-2002 | 01:46 PM
Question Tire Pressure?????
I Need To Know What Exact Tire Pressure I Need To Put In My 18x7.5 Wrapped In 225/45/18 so That The Rim Is Stronger And Wont Bend As Easy... Last Time I Put 38 or 36 Pounds Of Air I Hit A Little Pot Hole And That Was It A Dent Big Enough For The Air To Leak Out...
Old 05-27-2002 | 09:47 PM
Lawaia's Avatar
Moderator Alumnus
The recommended tire pressure is provided by the manufacturer. It also depends on the tires load ratings. Check the sidewall of your tire; it will give you the max pressure rating for your tire. Make sure you stay within the recommended limits.
Old 05-28-2002 | 01:11 AM
Jax's Avatar
Jax
Re: Tire Pressure?????
did you happen to go to that place redline or something in queens about getting ur rim fixed? cause i forgot and was curious to see if they can fix my 3 piece rim
Old 05-28-2002 | 01:39 AM
yeah i went today and they cant even do it, once i said three piece they said uh uh... i think they only fix the inner part of the rim...
Old 05-29-2002 | 10:33 PM
FLL Type-S's Avatar
Iconoclast
I may be wrong here, but if you have a 3 piece wheel can't you just replace one of the three pieces that's bent?
Old 05-31-2002 | 02:12 PM
Racing Hart Dont Sell It, Thats The Problem
udelslayer
1G RDX Problems & Fixes
05-06-2016 01:27 PM
mugen_kid
11-13-2015 11:38 PM
NBP_BALLER
09-23-2015 09:18 PM
CostcoFanAUS
09-18-2015 07:05 AM
HeloDown
09-08-2015 07:51 PM
