Tire option for 18x9.5 all around!
Old 07-26-2016, 07:42 PM
DavidPitsul's Avatar
So I have 18x9.5 all around...I was wondering what tire set up I could use without any rubbing! Stock suspension for now! 2007 Acura TL
Old 07-26-2016, 07:48 PM
Andrew
VisualEchos's Avatar
Depends on your offset.
255/40/18 was my choice with 18 x 9.5 +40 for a super smooth ride, and no rubbing. Looks about as fantastic as you can get with the stock suspension IMO (takes up a little bit of wheel gap).
Summer.
by Andrew Thompson, on Flickr
Old 07-26-2016, 07:59 PM
Summer.
My offset is +30
Old 07-27-2016, 07:40 AM
Andrew
Originally Posted by DavidPitsul
My offset is +30
+30 is way to aggressive for a 9.5" wheel and stock suspension. If you had the 255/40 I mentioned you'd poke 15mm in front, and 10mm in rear. Mexican style. lol
This means that you need to take 15mm away from your tires, so you need a 235 to not poke, which is quite a stretch on a 9.5" wheel.
Old 07-27-2016, 11:14 AM
What about a 245/40R18?
Old 07-27-2016, 02:23 PM
[QUOTE=VisualEchos;15811299]+30 is way to aggressive for a 9.5" wheel and stock suspension. If you had the 255/40 I mentioned you'd poke 15mm in front, and 10mm in rear. Mexican style. lol
This means that you need to take 15mm away from your tires, so you need a 235 to not poke, which is quite a stretch on a 9.5" wheel.[/QUOTE/]
Found out that my offset is actually +35
Old 07-27-2016, 02:27 PM
Summer.
My offset is +35 just looked..
Old 07-27-2016, 05:28 PM
Andrew
That's better, but you're still out of the comfort zone of +40 to +45 for a 9.5" wide wheel on stock suspension. But again, it's all about the tire, and not just the size (they all run different), the specific tire.
Old 07-27-2016, 05:53 PM
What is something that makes sense? I can roll some fender if needed but want to keep everything else fairly stock..
Old 07-27-2016, 07:49 PM
Jeff
Oh Sickest TL's Avatar
if you can roll fenders then you should be able to figure this out
Old 07-29-2016, 01:07 PM
champaned_out's Avatar
i dont know why people keep saying 9.5 with +30 offset has alot of poke.. im running 18x9.5 +30 with 235/40/18 tires square stance all around dropped on Tein S Techs
No fender work required and no rubbing... tried to make it rub by having 5 people in the car and took aggressive turns but it turns out the TL can handle these wheel specs and drop just fine.. its a very minimal stretch for 235s on a 9.5" and you can see visually in the first picture the stretch is very mild... 225 however on 9.5" will be a a pretty aggressive stretch
theres almost no poke, as far as i can see.. imo it sits almost flush with the fenders in the front
I can tell you running 245s would absoluetly rub on my setup... you could probably pull off 245s on stock height, the suspension shouldnt compress far enough to the point where the tire and fender meets when your riding that high.. unless you hit a speed bump or pothole at a high rate of speed
Attachment 120350
Attachment 120356
Old 07-29-2016, 01:30 PM
Dang! You got yourself a sweet set up! Yeah I'm going to the shop today to look at some options and mount up my new wheels and see how they do. I'm really wanting to do 245/40 all around but I might just have to go for the 235 as that makes the most sense. Do you rub anywhere with your set up? Even on some pot holes or anything?
Old 07-29-2016, 01:45 PM
thanks man but yeah i dont rub at ALL, like i said i tried to make the car rub but it just wouldnt no matter how much stress i put on the suspension... MAYBE if i have a hundred pounds of gear in the trunk plus 5 people
i can imagine the rears would rub.. but that situation would be extremely rare
235s would be the safe bet but it also depends on your style and what you like
Old 07-29-2016, 02:02 PM
I do like to go fast sometimes but I'm a careful driver so I try to avoid the pot holes and such. Obviously their won't be any off roaring and for the now the suspension will stay stock...I do end up giving people rides pretty often so I don't not want to rub and do not want to fender roll...and I want more pics of your tire set up! From the side and some angles!
Old 07-29-2016, 02:18 PM
yeah i can get you some different angles of the setup, ill see if i can upload some when i get off work later today
Old 07-29-2016, 02:50 PM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
just remember that every single car is different. just because one user doesn't rub doesn't mean you won't. i did the same thing when i first started researching stance and wheels, and i got the same exact setup as someone else and mine rubbed and he didn't. just keep that in mind, it's not going to be exactly like anyone else's setup.
the setup up above looks to have some poke. my last setup had the same outside position (mine was 8.75 +20...which is pretty much the same as 9.5 +30) as shown above and there was for sure poke. my setup now is what i consider flush and it's 9 +32.
Old 07-29-2016, 03:36 PM
At the moment I have ESR SR05 18x9.5 +35 sitting in boxes...just looking for some opinions and if people are running similar set ups
Old 07-30-2016, 12:50 PM
Thanks guys! 245/40R18 on 18x9.5 +35
Old 07-31-2016, 08:03 AM
llllBULLSEYE's Avatar
looks good now drop it asap
Old 04-28-2017, 07:46 AM
Rick Taylor's Avatar
So your running 235 40 18whats your drop
Old 05-26-2017, 08:40 AM
Steelhead 6.2's Avatar
This is a helpful thread! I just ordered some new Miro 111 wheels for my 07 TL-TypeS. The specs are 18 x 8.5 with a +35 offset. Just to be clear, I can run a 245/40r-18 with no rubbing issues?Or even a 45? Keeping it at stock height for now as well.
Old 05-26-2017, 09:27 AM
sockr1's Avatar
yes you can run a 245/40 and that's what i'd do. don't do 245/45
are you sure those wheels clear the brembo brakes??
Old 05-26-2017, 03:28 PM
Yeah, no! I won't be running Brembo's, but thanks for there input! I think I will go for the 245's and give it a nice beefy look!!
Thanks!
Old 05-26-2017, 05:27 PM
sockr1's Avatar
Thanks!
if you have a type s...you have brembos hahah. that's why i said i hope you know they clear or you will need spacers
more often than not, 18x8.5 +35 will NOT clear brembos, which you have on your car
Slpr04UA6 (05-26-2017)
Old 05-26-2017, 06:14 PM
-------Tim-------
Slpr04UA6's Avatar
Steelhead-so what are you going to do with your stock Brembo's? Downgrade to base calipers? Or run spacers?
Old 05-26-2017, 08:01 PM
Oh man! ..... For real? I'm new to this, but you would think that if the factory +40's clear that a lower offset would easily clear. I am familiar with offsets as I have done aftermarket wheels on my F-150. It comes with a +44 offset and I put a -13 wheel and it sticks way out farther and gives more clearance of UCA's and brakes. Is it not the same with cars? The closer you got to 0 , the farther ir sticks out or pokes. Thats why I assumed it would clear! What offset will clear then? or I guess I will have to go spacers (which I'm not a fan of) or different brake pkg that clears!
But aren't others on this thread running a +35 without issues. I based my decision on those previous posts on this thread. Sorry for a little bit of a hijack on this one Davidpitsul!
Old 05-26-2017, 08:07 PM
sockr1's Avatar
it is very hard to find the wheels that give a functional stance and clear brembos. the offsets play a weird game with our brakes. the rule of thumb (most of the time) is that +32 and lower (+20, +22, etc) clear the brembos. there are very few 18x8.5 +35 that clear the brakes. the ones i know are enkei raijin and some of the vmr wheels. the guys above were mostly referring to wheels that clear the non brembo brakes which are found on 2004-2006 automatics and non type s 07-08. i spent about 3 months researching before buying my sets of wheels each time i changed.
wait until the wheels come in and then decide if you need spacers and if so, how thick. i hate going spacers and will never run them on my car, but that choice is up to you, many people use spacers but none of the big box stores around here will touch your tires/wheels if they see spacers.
to change your brake package is a VERY big job and will be costly and to put it lightly...dumb haha. people would love to have brembo brakes
Old 05-27-2017, 12:26 AM
Great info! Can't thank you enough !! Thank you!
I just ordered them today, so first thing tomorrow I will be changing my order!! I really do not want to run spacers!
Old 05-27-2017, 10:37 PM
My next option is to go with the 19 x 8.5 with a +15 offset. Still want to run a 245 tire. I do not want a stretched tire . In fact,I would rather one that has some rim protectors .
Thoughts?
Old 05-27-2017, 11:42 PM
I'm confused!! Will a + 40 offset at 18 x 8.5 fit? Do I have to go up in offset to clear Brembo's?
Old 05-28-2017, 08:39 AM
sockr1's Avatar
40 will not clear. Only oem
Thoughts?
With those wheels specs you would need a 225/40 tire more than that and you might rub or hit the fender. Your wheels would have major poke too (stick out past fender)
Old 06-20-2017, 08:51 AM
I will be keeping my Bembos!! Likely will run spacers because its just so damm hard to find a wheel that I like, that will clear.
Old 06-20-2017, 01:44 PM
Le7316's Avatar
Keep looking...its out there and there is a thread about the wheels that clear Brembos !!!!!
Old 06-20-2017, 08:33 PM
evarela25's Avatar
I'm currently running v710 18×9.5 +33 with a 245/40 tire but even with rolled fenders and shaved down bumper tab I rub occasionally but nothing crazy only on really big dips in the road
Old 06-20-2017, 08:58 PM
sockr1's Avatar
love your setup! what were your front and rear camber specs on your last alignment? natural camber?
Old 06-22-2017, 12:07 AM
evarela25's Avatar
Thank you, If I recall it was -1.3 front and -2.3-6 in the rear and yes natural camber.
I think you should make the switch lol, but maybe pick up the v710 ff since the v710 are heavier than your wheels
sockr1 (06-22-2017)
Old 06-22-2017, 10:59 AM
sockr1's Avatar
thanks for the specs. man i would love to get on the vmr 710 but it's always a hassle selling wheels. if i do, i would go with the 8.5 +35 and add 245/40 tires
i was asking about the specs because i currently have less aggressive specs (18x9 +32) and run 235/40 tires but i would love to run 245/40 tires next time and was seeing if i have more natural camber in front. i think i'm about -1.7 or so in the front so i should be ok with 245/40...even though i have to wait about 2 years for my current tires to need replacement haha
and i can't get the v710ff, they only come in matte graphite and i'm not a fan of dark wheels on white cars. i'd only get hyper silver and it's not offered! oh and it only comes in 19 and i wont' run 19s on my car haha
Old 06-27-2017, 09:22 AM
Nemowuner's Avatar
18 x 9.5 with 45 offset
2007 TLS
18 x 9.5 +45
225/40/18
will this set up work ? I'm already in coils. There is a lot of info and my brain hurts. Please and thank you !!
This is the car
These are the wheels
Old 06-28-2017, 12:48 PM
Andrew
Originally Posted by Nemowuner
2007 TLS - 18 x 9.5 +45 - 225/40/18 - will this set up work ? I
No one can tell you because it's all about the wheel design, you'll have to put them on and see. In theory the sizes will work, but you need to check the brake clearance. You also need to get a life and choose something bigger than a 225!
Old 06-28-2017, 03:56 PM
Nemowuner's Avatar
What give you the need to think telling anyone to get a life for asking a question that are related to the atmosphere of this forum is something acceptable?
I appreciate the assumption of your beginning statement but I don't come on here for some wise ass remarks. If there is a problem with 225 why not state the reasons why?
Quick Reply: Tire option for 18x9.5 all around!
