Tire noise? Maybe bearing neex help.
First of all 2008 tl s 6 speed.
I did an alignment andbalance tires not tol long ago. It seems to make a terriblr noise and steering wheel shakes at about 65 mph. This hasbeen happeningbefore alignment and balance tires. I need ideas where to start looking for the real problem. Please and.thank.you
Steering wheel vibration at 65/75 is a prime target area for balancing. Chances are they are out, but if the same size front/rear switch them around and give a try.If you have the same shop do a rebalance, after the assembly is done, have them rotate the tire 180 degrees and spin again. If out again, either the balancer is out or center hole in wheel is out. Have them use the lug adapter to affix the wheel to the machine.
Mike Bertram
09-10-2015 09:27 AM
