Tire balancing wheel weights
I'm trying to re-install my OEM wheels back to my 05 TL. I'm kind of confused which wheels go front and rear. I noticed balancing weights are differet for front and rear. What will be my solution to this?
Lt. Dangle
The weights are there to balance the wheels regardless of placement on the car. Unless you have unidirectional tires, it does make a difference. And even then, the front and rears on the same side need to be interchangeable so you can rotate them.
1fatcrxnem1
22
06-01-2018 01:23 AM
