Tien springs and Tokico adjustable struts squeaking
So, the problem I'm having after installing my new set of Tokico adjustable struts is the damn squeaking noise from my back suspension now. I original had Tien springs with stock struts and had to replace the stock struts because they went bad. I had no noise what so ever from them and they rode awesome. I then purchased a set of Tokico adjustable struts and for the past week they have been making squeaking noises only in the rear. The front don't make a sound at all. I've had them on for about a month or two now. I've also notice that the first two weeks I had them on the ride was so smooth and now when I hit a bump or dip it feels like my damn suspension is about to fall apart lOl... I've tried to adjust them harder or softer to see if the noise would go away and maybe smooth out the ride. At this point I'm not sure what else I should do. Anyone out ther ran into the same problem and can suggest what I can do to fix it. I'm tempted to just buy stock struts again and replace the Tokicos. I've had the dealership look at my suspension already and they said since the springs and struts aren't factory they can't do anything about it. Help please...
All Around Klown
is it poly bushings or rubber... if poly then try some silicone grease on them. You also might want to check the tightness of the mounting bolts to make sure there isnt any slight play.
Factory rubber bushings, both sides are squeaking. I bought them from Joshua (Excelerate). I notice the struts say they were for Honda Accord. Would that make a difference? I know there are alot of parts that are interchangeable
Former Sponsor
Usalinh (11-04-2012)
Thanks Josh for the advice. I can't find a reliable place down here to go to and each time I ask them something it sounds like they are trying to get me to get some more work done on the car to get paid
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
