Are they b.sing me about offsets?
Everyone tells me a 40 offset will fit and will not rub? are they b.sing me or is it true? anyone with 17" with 40 offsets? 18x7.5 with 42 offsets in the NYC area ?
dude, trust me, i had some 17's with +40 offsets and they rub on every corner or ditches even on 215 tires, so don't do it unless you want to waste your money and time.
Bada Bing
I'm running 18x7.5 with a 42+ offset. I'm lowered on Ground Control coilovers and I rubbed in the rear under a full load with 225/40/18 tires. After cutting the bumper tab, and rolling the fenders the problem was solved.
As for the 17's...I have no ides.
i wouldnt do it unless your ready for some problems i.e. rubbing
If you're getting 7.5 inch width then get atleast a 48+ offset (and you still might rub depending on the tires). If you're going with 8 inch width then get no less thatn 50+ offset. With my setup I'm fine 18x8 50+ offset, drop
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
