Is There a Koni Yellow Install Guide?
I just got my Koni Yellows and H&R springs. Let me tell you the instructions are absolute rubbish and you might as well have not even provided them. This is really disappointing because I thought the install would be a breeze. I have the FSM for the car and the exploded view of the assemblies. Is there anything I should be aware of when assembling these? How do you adjust the spring perch clip for adjusting the ride height without breaking it? I'm also guessing that the orientation of the spring perch also adjusts the ride height. Can someone throw me a bone here?
-------Tim-------
Yeah the instructions are crap. What model Tl do you have? Adjusting the perch clips isn’t that difficult, I can’t remember the name for the tool you could use. It’s a clip spreader, is best I can describe it. You can also just use a flat head srewdriver, but the clip and screwdriver can mess up the paint on the shocks. I have a base Tl, but upgraded to the type-s bushings, which need to be drilled larger to accommodate the koni shaft. I’ll try to find the thread I used to help with the install. The bump stops can be cut slightly, like a 1/2”-1”. They will slide over the koni shaft with some force. Spring cups should be mounted the same as OEM.
here is a thread with some help.
https://acurazine.com/forums/3g-tl-t...shings-837206/
Lazer187
38
05-02-2012 10:09 PM
