Suspension help please?
Hi everybody,
Just joined the forum after finding a bunch of helpful articles, but it came to the time where I was no longer able to find an answer to my questions. I'm driving an '05 TL 6MT and my cousin gave me OEM 06 TL AT suspension. I am aware that the suspension setup between the AT and MT are different, at least that's what I saw on another thread. I do know that the 06 suspension will fit my 05 MT, but in your opinion, is it worth doing this? How would it affect the ride? I only ask because it's about time that I replace the suspension anyways. Thanks!
Also, I've been thinking about getting lowering springs with a Progress 24mm RSB, but I saw on the forums last night there were issues with people mounts tearing the rear subframe. I drive primarily in NYC, so the roads are horrendous. Has anyone ever found a way around this? Thanks!!
Miles on both would help make this determination easier..
Way around ripping subframe? Don't install a Progress. You can always try to just upgrade to a TL-S RSB which should be more forgiving.
Honda often uses different spring and damper rates to account for the weight differences between AT/MT models.
So your MT might sit a bit higher and/or ride a bit stiffer using the AT suspension.
If the progress bar has issues ripping out the subframe, maybe a better bet is a 22mm TL-S bar? How big is the factory bar? I have no idea what the spring rates are for the available TL sway bars. So hopefully, someone can chime in. If all the available bars are solid...then its easily deduced that bigger = stiffer. Does the Progress bar have stiff/soft mounting points?
I'm guessing you want to lower it to just have a bit more fun in your DD? Is ride comfort a significant factor for you?
I drive in NYC all the time. For me, having a suspension with compliance really matters in that environment because the roads are pretty torn up.
In any case....have you looked into Tein Street Advance Z (SAZ) coilovers? When set up properly, the comfort is improved over stock...and the ride dynamic (body roll, etc), is also improved over stock. You win twice.
shottyploxx (08-30-2017)
