Suspension conundrum...
Old 05-14-2015, 11:09 AM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
As of not too long ago, I've been spending more time driving my summer toy while the TL sat parked. Well, about two weeks ago I decided to take the TL out and I kept thinking "man, the handling feels like shit on this car"
Granted, I've been a bit spoiled by the summer toy, but there's something definitely not right with the TL and it started pulling to the RIGHT even though I know I didnt hit anything. I knew I had the compliance bushings left to do, so I figured that was likely the cause of my grief. When I pulled out the lower control arms, I figured since I was already in there that I would replace all 6 bushings on the arms (3 per side). Oddly enough, none of the bushings were really even all that bad. I'd rate the compliance bushings at like a 7.0-7.5/10, in terms of wear.
When I was taking the car apart, I noticed the inside of my LEFT tire is worn badly. Like a 1" wide strip of very worn tire compared to the rest.
The TL has new sway bar end links, new compliance bushings, and new 4 other bushings. Upper ball joints don't generally need to be replaced, so I'm ruling those out- could it be my lower ball joints are pooched? How can I tell if they are? They looked okay when I seperated them from the LCA and I haven't heard any sound coming from my suspension...
Is this just a case of me needing an alignment or is there something else I should look into? I feel like the uneven tire wear happened rather quickly (although I can't prove that). If that is the case, I dont want to be driving the car on some new summer tires I have for it (the worn tires are winters and this was their last season, however, that one tire was weirdly worn even more).
Thoughts? Ideas? What to check? Don't think it matters, but the car is a 2006 TL 6MT
Old 05-14-2015, 11:35 AM
TacoBello's Avatar
FFS... due to a certain lazy member ... Cliff's notes:
1. TL drove fine.
2. TL sat for a week.
3. next time I drove the TL it pulled to the right and I didn't hit anything
4. I replaced all LCA bushings (it was time to do so)
5. Haven't driven the car since replacing bushings.
6. I'll be going for an alignment shortly
7. Is there anything else that could be messed up? lower ball joints? How can I tell?
8. Anything else that could be pooched?
Old 05-14-2015, 11:37 AM
TacoBello's Avatar
FFS yet again... summer toy is a Miata. Happy?!
Old 05-14-2015, 12:26 PM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
Driver front tire only? Ball joint isn't loose or anything?
Get an alignment. Get the specs printed prior to alignment too and share here. What's the price anyway, $60?
Old 05-14-2015, 02:02 PM
TacoBello's Avatar
Yeah, an alignment is cheap, but if my ball joint is messed, I don't want to pay $60 now and $60 again a week later.
Maj, where are you?! Give me your advices!! Don't make me take this to 3G ramblings...
Old 05-14-2015, 02:03 PM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Flipster23's Avatar
Ask Justn
Old 05-14-2015, 02:23 PM
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
Toe and camber.. at minimum, get the toe back in order.
Old 05-14-2015, 02:25 PM
TacoBello's Avatar
Any chance it can be the tie rods going? I've never really heard of people replacing them on the 3G, although I could be wrong...
Old 05-14-2015, 02:26 PM
TacoBello's Avatar
I was thinking toe is out also, but hoping I could check other stuff. I found an old 2G post about checking suspension...
"You're describing "unloading the ball joints", which is necessary on many cars. It does NOT apply to our front ends. Both upper and lower ball joints are unloaded with the wheels hanging free.
Typically, just grab the tire and try to shake. Play at 12:00, upper ball joint. Play at 6:00, lower ball joint. Play at 9:00 or 3:00, tie rods or steering linkage."
I'm gonna try that when I get home tonight
Flipster23's Avatar
Report back after you try it.
Old 05-14-2015, 02:27 PM
TacoBello's Avatar
Don't judge me.
Old 05-14-2015, 02:32 PM
Majofo's Avatar
Ball joint is easy.. check if it's taught. If it has a lot of play, press a new one in. Make sure you spec the castle nut and put a new cotter pin back. I doubt it's out and definitely wouldn't make it pull right. Are you on aftermarket suspension?
Also, salad for thought.. if the left tire has inside wear, that means the camber and toe are probably out. The left side is not only applying more force rightward, but with that wear, more traction as well.
Report back your numbers when you get them.
Old 05-14-2015, 02:44 PM
Majofo's Avatar
Only if it's fucking with the alignment. If you didn't hit anything, or fuck with it. I'd rule it out.
In my experience, it has to be really out to feel for play. Play in the wheel can also be the wheel bearing.. you'd know if it was a wheel bearing though.
Definitely get a year alignment deal. Usually an alignment is 50-80.. or 1yr/3yr deal for less than the cost of 2 alignments. You might be back again, or decide on fking with the suspension, so it's worth it. Worst case, say you traded in your TL for the miata and it becomes transferable to the new car.
Old 05-14-2015, 03:09 PM
TacoBello's Avatar
Suspension is more or less stock. A-Spec struts with Eibach springs, if I'm not mistaken. Maybe H&R springs. I don't remember. Wasn't my choice, but what the car came with.
Other than that, up front, everything is stock. FSB, end links, bushings, control arms, ball joints, tie rods, you name it.
I'm gonna take it for an alignment tomorrow. My girl at the service department is hooking me up. The Honda dealer she works at charges $69.99 for an alignment on unmodified cars. It's $120 if modified in any way, shape, or form. I'm getting the $69.99 price.
Old 05-14-2015, 03:12 PM
Majofo's Avatar
Why not 34.50? You guys don't have legit tire shops up there that do 1/3 yr deals?
Old 05-14-2015, 04:29 PM
TacoBello's Avatar
I actually have no idea what that is, lol, so I'm guessing no.
Honestly, you 'muricans have it damn good down south of the border. Don't take it for granted!!
Old 05-14-2015, 04:36 PM
Flipster23's Avatar
NO Maj that's 34.50 for us... sixty nine nindy nine fo them...
Old 05-14-2015, 05:26 PM
Received 8,753 Likes on 6,750 Posts
Some shops down here have 1 year unlimited alignments or 3 years or even lifetime alignment packages.
I feel you doe, I would hate to do an alignment and realize my shit was broken and it would need another one. One thing to note if you're afraid it's tie rods or other component is ideally the competent tech doing the alignment would see something wrong and say "HMMM this tie rod looks bad, I won't be able to do an alignment " and you can go from there..
But then again this is canada, I question everything out there..
Except poutine
Old 05-15-2015, 10:28 AM
TacoBello's Avatar
Update!! Update!!!
Well, I finally put my summer tires on yesterday evening. Gave the wheels a firm shake at 12:00, no movement. Gave the wheels a firm shake at 6:00, no movement. Gave the wheels a shake at 3:00 and 9:00, no movement.
After reassembling everything, I took the car for a drive... it drives straight again, lol. Yay! No need for an alignment. I'm sure errrthang is jus' fine
Old 05-15-2015, 10:29 AM
TacoBello's Avatar
Kidding. Took the car in for alignment this morning. Should have it back in a couple hours (didn't want to sit around waiting). Will update if my toe was just out of whack.
Old 05-15-2015, 10:30 AM
Majofo's Avatar
Old 05-15-2015, 11:28 AM
Flipster23's Avatar
You got spanked anyway....
Should have just posted in 3G ramblings
Old 05-15-2015, 11:31 AM
Majofo's Avatar
Spanked for bullshitting say there's no problem, when obviously problem.. This one's for you ->
Old 05-15-2015, 11:40 AM
TacoBello's Avatar
Hahaha, this really is the undercover 3G ramblings...
Car is waiting to be picked up. I won't be able to grab it for another 90 minutes though... Tied up on AZ
I'm hoping the alignment I've magic cure. Secretly, I'm still thinking the bushings were responsible... The car stopped pulling to the side after replacing them. That, or the other wheel was knocked out of alignment the same amount to cause the car to track straight
Old 05-15-2015, 12:48 PM
nfnsquared's Avatar
Received 1,795 Likes on 1,348 Posts
I seriously doubt the bushings were responsible for the pull.
But since the struts are not stock, it's possible whoever installed them did not follow proper procedures when bolting everything back after the install (e.g. put weight on each side before torqueing everything down).
It's possible that just a simple, correct re-torqueing after changing out the bushings is all it took to fix the pulling issue.
Or maybe not, we'll have to see what the alignment shop says to get a complete picture...
Old 05-15-2015, 12:57 PM
TacoBello's Avatar
Struts are stock. Well, A-Spec stock. Springs aren't. Either way, they've been on the car for at least 6 years. Bolts seemed properly torqued when I was pulling them off. Plus, I drove the car for a good 15,000km without issue.
For all I know, wifey may have taken the TL and hit a pothole and wouldn't admit to it, lol. Leaving soon to pick the car up. Yay!
Old 05-15-2015, 02:49 PM
TacoBello's Avatar
I got the car back... and it works! Alignment solved the problem... looks like I'll be having a chat with Wifey regarding how the alignment was "mysteriously" out... *stink eye*
TacoBello's Avatar
Old 05-15-2015, 02:54 PM
Majofo's Avatar
dat camel toe! I wonder if the rears were purposely out-of-spec..
Old 05-15-2015, 03:37 PM
TacoBello's Avatar
Not that far out of spec! I actually haven't noticed any uneven tire wear with that camber. Yay for me. Gotta be able to hit them corners at light speed
Old 05-15-2015, 04:03 PM
Registered Bunny
polobunny's Avatar
Ok alignment shop. I'm surprised you noticed pulling to the right though.
Old 05-15-2015, 04:08 PM
Majofo's Avatar
:pb: It doesn't seem like much but even a little will be polarizing. There's a lot of force involved and it magnifies the faster the wheels are spinning + add in the additional traction from the inner wear.
polobunny (05-15-2015)
Old 05-15-2015, 04:18 PM
TacoBello's Avatar
I could be wrong, but I think :pb: meant that he would have expected the car to pull to the left with the left toe being out. I'm just pulling straws here though.
Old 05-15-2015, 04:21 PM
Majofo's Avatar
Left toe was toe-in.. looking from above, your front wheels were like this:
Hence the pulling to the right.
Old 05-15-2015, 08:06 PM
Registered Bunny
polobunny's Avatar
Ah yes, checked quickly when about to leave work. Toe in on left and small toe out on right could def exacerbate the feeling.
So maybe pressure the wifey about the left wheel. WHAT DID SHE DO??
Old 05-15-2015, 08:09 PM
conundrum solved! let the salad tossing continue!!
or did it ever end...
The wife probably hit a curb or something
Old 05-15-2015, 10:51 PM
Majofo's Avatar
It's not unusual for the toe to go out-of-spec. Surprisingly, Justn's toe was fine when he hopped the curb. I mean his wheel came off but it stayed straight.
polobunny (05-16-2015)
Old 05-16-2015, 02:25 PM
TacoBello's Avatar
Hahahahahahahahahahahahaha.... This just made my morning
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Suspension conundrum...
