Super Star Leon Hardiritt Orden wheels HELP !!!
Hey acurazine members need some advice on which wheel size and offset I should run I kno I'm going 19" I'm going for a VIP look but not so aggressive because the cars is still a daily driver.. considering going on bags and I do not mind doing fender roll and pull I was thinking about getting the Super Star Leon Hardiritt Orden wheels
Options that I was considering
19x9.5 +22 front
19x10.5 +25 rear
Or
19x10.5 +25 all around
Any advice will be greatly appreciated .. Thanks
19x9.5 +22 front
19x10.5 +25 rear
Or
2014 Jeep SRT
19x9.5 +22 front
19x10.5 +25 rear
Or
19x9.5 +22 front
19x10.5 +25 rear
Or
GTFO!
justnspace (02-18-2014)
Pghpizzaman (02-19-2014)
"VIP" and "not so aggressive" don't really go together.
You'll need to run quite a bit of camber even with stretched tires so you don't rub. Without a doubt your rear fenders will be need to be rolled. Order the 9.5s up front, even though that prevents you from rotating tires.
those the 9.5/10.5 specs are similar to my LXZ's, they'll fit with minimal camber, stretched tires and rolled fenders
the 10.5 all around will need a good amount of body work and camber up front
blah
Are you getting the reverse lip or the step lip Ordens?
With the specs you listed (assuming low-disk), the rear is going to have a 76mm lip and the fronts will have a 64mm lip (you probably meant 19x9.5+25).
These are small lips so be sure you're okay with that.
10.5 for the fronts is too wide. Go with the 9.5 and 10.5 if you want to keep it stock looking.
rockyboy
08-04-2024 10:35 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
drewdeezy03
09-03-2015 08:04 PM
