Stretched tires
Old Jul 15, 2012 | 09:54 PM
seeya1's Avatar
Stretched tires
Do stretched tires perform much different than a non stretched tire? I would image so I am hoping some of you that are riding on stretched set ups can inform me of the expected differences. I have an 04 Auto TL 19x8.5 with 225/35/19 up front and 19x9.5 235/35/19 on rear 35mm offset on both.
Old Jul 15, 2012 | 10:08 PM
Italiano's Avatar
no reason to be runnin a 225/35 in the front with those specs...if u were sittin flush and dropped pretty good i could understand...i would bring that to a 235/ front...and in the rear u could do a 245 series...alittle stretch wont hurt but needs to be justified to do it
Old Jul 16, 2012 | 12:03 AM
rptls08's Avatar
WDP Type-S sitting on air
i agree with those specs you shouldnt need to stretch your tires unless you are pretty low but even then i dont see the need for much stretch. also what tires are you using. different tires react differently to stretch so if you are stretching you will want to have a tire that stretches well.
Old Jul 16, 2012 | 06:06 AM
seeya1's Avatar
Im dropped HT spec 2. 2" to 2 1/4" all around without being rolled. Tires seem to be just clearing the fenders as it sits I was afraid if I went a little wider I would need a roll. I will post pics later.
Old Jul 16, 2012 | 08:11 AM
SharksBreath's Avatar
BANNED
need to pics to see where you stand...but from the specs you listed, i would just go with a 235/35 all the way around.
i'm running a 225/35 on mine but i have much more aggressive specs than you.
always always run a more appropriately sized tire if you can. more cushion, no exposed lips, more comfortable, better handling, you get the idea.
in for pics.
Old Jul 17, 2012 | 07:38 PM
bluetl04's Avatar
yes...in for pics as well...i am in the same boat about buying less wider tires so i can put spacers on...
BreezyTL
Jul 26, 2016 12:52 PM
PortlandRL
Sep 14, 2015 12:01 PM
fallacy
Sep 4, 2015 10:15 AM
nuldabz
Sep 3, 2015 05:49 PM
