Stock Ride Height (from ground measurement requested)
I looked for a while and found lots of things on what lowering would do, but nothing that indicated how high off the ground the top of the wheel well is from the ground on a stock TL-S, 2007.
I measured and have a difference between wheels of up to an inch. I need to double check on flatter ground (read as in the garage).
Anyone have the ride height, as measured from the top of the wheel well to the ground? Type S, 2007 preferred.
I'm trying to see if the shocks are bad - it's a rougher ride than my 2003 Type-S.
Just an FYI, our '04 with 245/45-17's, about the same height as the OE Michelin's, is about 26.5" at each corner when measured ground to bottom of fender through center of wheel.
Chances are shocks aren't bad as if they were the care would be bouncing over the bumps.
justnspace (05-18-2014)
1fatcrxnem1
22
06-01-2018 01:23 AM
Joseph Stansbury
34
12-04-2015 01:57 PM
09-14-2015 10:48 AM
