Steering Wheel Off Centered.
Does anyone have the same problem as mine? I bought a 07 Type S and the steering wheel is a little off center. I took it back to the dealership a few times and they did a couple of alligments and it made it a little bit better, but the problem still exist. What do you guys think?
06 TL 6spd. Navi/A-spec
Like said the toe is off and the alignment should have fixed it, there is a cheating way to fix this also without alignment, all you have to do it loosen the tie rod nuts and lenthen one and shorten the other equally just a little it depends on which way the steering is off right or left, that should fix it, this is what honda and acura's new way of fixing pulls on warranty jobs, but if you are inexperienced with this i wouldnt touch it and let the dealer deal with it because it might make it worse if not done right!
I appreciate all the inputs guys!!! I'm not going to touch it. I'll just take it back to the dealership and have them fix it for me. Afterall it is a 40k dollar car. Thanks again guys.
rockyboy
12-06-2022 02:29 PM
EvilVirus
12-10-2015 07:38 PM
