Steering responsiveness
Old 01-02-2016 | 01:13 PM
Jsanchez116's Avatar
5th Gear
What's up guys. First of all I want to say I love this site, you guys have answered my questions before I could even ask them, which is why it took me so long to register. Now down to business.
I have a '05 AT TL with about 83k. I recently upgraded to a koni yellow/eibach suspension. I've seen all the praise given to the konis and tried them out. For some reason I can't figure out why my car isnt handling how I think it should. It's just not tight, I get some vibration at speed and an annoying hum from my right side. I don't feel confident in corners.
I changed my rear bearings to Moogs and am going to change the front as well. I am also going to purchase a progress rsb with moog endlinks. I was thinking it could be bushings but I'd rather replace the part then the bushing. Before I go off and spend all this money I need some help figuring out if it's the right part. Thanks guys.
Old 01-02-2016 | 01:30 PM
paperboy42190's Avatar
hm, suspension shouldnt be causing a vibration/hum, are you sure its installed correctly?
Old 01-02-2016 | 01:36 PM
5th Gear
It's definitely installed correctly. I feel the shocks working fine under me. I think the vibration could be one of my front bearings or my rotors. I dont want to change my rotors until winter passes though. My steering tightness and responsiveness left and right is what's getting at me the most.
Old 01-02-2016 | 07:08 PM
csmeance's Avatar
how are the front control arm bushings? Rear suspension bushings?
Did you get an alignment after the install? Once you drop the car or change suspension parts, the geometry changes! A small change in toe or camber can have a large impact on how the car feels.
If it's feeling twitchy and unsettled, your toe probably is out. You'll also need a camber kit to correct the negative camber for the rear.
Old 01-02-2016 | 07:17 PM
5th Gear
I did get an alignment after the drop but I still have slight negative camber in the rear. Figured I'd get a camber kit when I get new rims and tires in the spring. And as for the bushings i'm pretty sure my control arms aren't doing too well. Any suggestions on what brands to buy? For the control arms and canber kit.
Old 01-02-2016 | 08:31 PM
csmeance's Avatar
You can buy the TL-S bushings for the front control arms (I believe $25 each) and get them pressed into your control arms. I did mine in my garage, about 3 hours total to do both sides.
Some folks buy the complete arm and replace that, which is fine but more work and more expensive in my opinion.
No clue on the camber kit, I think there's a thread on here on which one is best. Did the shop give you a printout and tell you what the toe was?
Old 01-02-2016 | 08:38 PM
5th Gear
Did you get the bushings pressed out by a shop? I was thinking an Ingalls camber kit but my drop was only an inch with the eibachs so the toe isnt crazy. Dammit I shouldve asked for a printout though. Hows the ride on type s bushings? Noticably better or basically stock?
Old 01-03-2016 | 01:46 AM
csmeance's Avatar
I used the 2004-2006 ones rather than the type-S since I didn't want to feel more road imperfections. I honestly tried to make the tool with parts from HD/Lowes and failed. Took a hammer to the parts I bought and literally beat the old one out and beat the new one in. I froze the new ones to help it slide in easier.
There's a whole thread in problems & fixes on it with tons of DIY's and youtube videos.
Old 01-03-2016 | 07:25 AM
Turbonut's Avatar
What size/type tires are on the car?
Old 01-04-2016 | 02:01 PM
Slpr04UA6's Avatar
-------Tim-------
Spc for rear camber kit. It will be one arm (up top) per side (rear). It will have a ball joint on one end. Ingalls doesn't have the greatest reviews (in the past). I used them for 3yrs, and the bushings became distorted, causing the Allignment to go out (had multiple alignments over the 3yrs,$$$$ wasted, to only find out the problem!), even after getting aligned. Save yourself the headache & cost, buy the SPC upper camber arm, and get aligned, and be done.
dirleton
12-03-2016 11:08 AM
silvio65
06-30-2016 08:59 PM
Groovemaster
01-12-2016 08:18 PM
yingers
01-12-2016 08:40 AM
starsh0t
01-03-2016 04:24 AM
Quick Reply: Steering responsiveness
