A-spec Tires
08 TL Type S A-Spec
I think those would throw off your speedometer. You will need to run 235/40/18 to compensate for the factory wheel size of 235/45/17 and keep speedo correct.
Besides, a 40 series tire will have a "stiffer" side wall and handle better with the 18" wheels.
Go with the 235/40/18 OR 245/40/18 (this will work too)
It depends what year A-spec wheels you buy. The 04s were 18x8.5 and 05-on were 18x8. I have the 18x8.5 and I run a 245/40, 235s dont cover the edges of the rim with the 8.5 inch wheel. 245/45 would throw off the speedo.
94 DC4 RS LSV/Turbo
245/40 is the quiet ride... 235/40 is a slightly noisy ride because there is less meat... but 235/45 or 245/45 will not only throw the speedo off but make the car feel like it is tipping into corners...
245/40-18 should have been the tire the car came with because it offers a quiet ride and sidewall protection
08 TL Type S A-Spec
+1
245/40/18 would look GREAT with the A-Specs.
Try the FALKEN FK 452s........you will love them!!!
www.discounttiredirect.com
Originally Posted by OneWickedTypeS
has anybody noticed rubbing, with 245/40/R18.
Cause i rub slightly when the wheel is turned?
MY KBP IS BTR THN URS...
Well i got a picture a couple weeks ago when i had the front end torn apart.
And i am not lowered yet, thinking about getting springs for the time being
ALSO FIRST TIME TRYING TO EDIT PICTURES LIKE THIS...
The Kinetics of Bleu
No The Piece Of Crap Jack I Had Barely Got The Car Up, And Then A Nasty Storm Rolled In So I Used The Blocks Incase The Jack Dropped Over Night. I Could Not Get My Jack Stands Under The Car. I Need A New Jack...
94 DC4 RS LSV/Turbo
alignment must be off... not supposed to be rubbing inside... regardless that isn't "real" rubbing... that is weather liner being dumb
I am lowered 1.5" 18x8.5 +35 245/40-18... and yes I've rubbed that same area but I have some negative camber
rockvilleTL
09-19-2015 04:44 PM
nuldabz
09-03-2015 05:49 PM
