A-spec suspension uneven drop
Don't know if anyone else had this problem with the Aspec suspension. I had them installed about 3 weeks ago. Today I was looking at the drop and noticed that the left side appeared lower than the right. I did the ol' finger check and there is indeed a slight height difference. Has anyone else noticed this?
Will
Will
I didn't get it installed at the dealer. Went to a local shop. Dealer wanted about $350 for the install. Ride is much better and the car doesn't seem to bounce as much when going over bumps. It could feel a little tighter though, not sure if the height difference has anything to do with it not feeling as tight as I had hoped.
Now with i-Vtec
Originally Posted by willz822
Why would there be more weight on the driver's side?
Battery, Air Box, Brake Booster, Steering Rack, Pedal assemblies, etc.. May not seem like a lot but it's enough to compress the spring a bit more on the drivers side compared to the passanger side. Plus when you sit in the car your weight is gonna help settle the springs faster.
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
