a-spec suspension package..
Old 09-25-2006 | 12:37 PM
Darknesss_TL's Avatar
acura dealer just told me the a-spec suspension package costs $2800!!! how much did everyone else pay for theirs? just curious where can i get it cheaper?
Old 09-25-2006 | 12:57 PM
chill_dog's Avatar
Oderint dum metuant.
The suspension package, as defined by Acura, is coilovers plus wheels and tires...$2,800 is list price. Check on eBay or with the dealers/vendors here to see if you can get it for less.
Old 09-25-2006 | 01:29 PM
jupitersolo's Avatar
nnInn
I order the suspension from Las Vegas Acura for $700 shipped, had a local guy, Dennis install for $150. I just order body kit from hondacuraworld for $800. Same guy will install for about same price. I'll have him put the RSB on as well.
I called local Acura to install suspension before I knew about Dennis. The dealer said it was a 6 hour job and with the alignment it was going to run $725. Dennis put it on with NO power tools and NO lift, in 2 1/2 hours.
Old 09-25-2006 | 01:47 PM
FiveLiterCheater's Avatar
Is the A-spec suspension just the coilovers? If they're that much...why not just get the Tien SS?
Old 09-25-2006 | 01:56 PM
nnInn
Yes it's coilovers. I went with Aspec because I didn't want a big drop, just wanted the tight-ass suspension. Also the Aspec was built specially for the Acura.
Old 10-03-2006 | 09:00 PM
maxAmillion's Avatar
2010 WDP TL Tech
Do you have to get an alignment after you install just the a-spec springs on the stock struts?
Old 10-04-2006 | 10:06 AM
chill_dog's Avatar
Always get an alignment after suspension work.
Old 10-05-2006 | 10:26 AM
t0talacuratl's Avatar
Green Machine
I would love to get the A-spec for that reason, but I hear the drop isn't that much. Can you tell if the car has been lower with the A-spec?
Old 10-05-2006 | 10:33 AM
chill_dog's Avatar
It lowers it slightly...half an inch to three quarters. I measured before and after and it dropped half an inch; it has settled some since, but not much. It does not lower it the inch Acura claims. It looks nice overall, and the improved handling is worth it, even if it didn't lower it at all.
Old 10-05-2006 | 10:54 AM
How does it compare to the Tien SS (handling-wise)
Seems like a good price for the A-spec, but the only downside is the .5" drop, whereas the SS are fully adjustable. Just from looking at it, I would think a car w/ tuned Tien SS's would handle better than the same car w/ A-spec coilovers. Maybe i'm wrong..
Old 10-05-2006 | 10:55 AM
Mansa24's Avatar
So it's just coilovers.
Old 10-05-2006 | 11:18 AM
Green Machine
Thanks for the feedback. I guess that would narrow it down to either Tein SS or Koni/Eibach combo. I really would like to have the look as well as the handling. Also like anyone, the cheapest way to go.
Old 10-05-2006 | 12:13 PM
nnInn
This is what you get. Just take them out of the box and put then on the car. The lower on the car looks nice. My left rear shock blew out 2 days after I got them on, waiting for a new one to come in.
Old 10-10-2006 | 10:32 AM
sftl97's Avatar
9th Gear
I would also like to get the Aspec suspension for my '06 6MT. Just moved to Dutchess county NY and if anyone knows an Acura dealer in this area which does good work, please let me know.
Fred
Old 10-10-2006 | 07:22 PM
csmeance's Avatar
FYI my dealer just quoted me 700 for the suspension and then 599.95 for the intall.
Old 10-10-2006 | 07:31 PM
DAMN $600 labor?! Theyre crazy....
find someone else to do it....
Old 10-10-2006 | 08:44 PM
whatjones911's Avatar
The install is really simple! If you have jacks and simple tools you can do it yourself. When i installed mine, i never had any expericence with cars at all. I still haven't even try changing oil yet!! So when i say it's easy, it's easy
Old 10-10-2006 | 09:54 PM
csmeance's Avatar
i did start to try, i removed the bottom seat (took 45 minutes) and then started to remove the top. I couldnet get to all the bolts and the back portion didn't come off. In the process, i think i might have messed up a few things so i most likely will give it to acura to do. BTW, i'm not all that good when it comes to ripping apart my car, but after acura does the a-spec install, i might remove the back seat to put in some dynamat. BTW, how old are you whatjones911?
Old 10-12-2006 | 03:13 PM
sftl97's Avatar
9th Gear
I just spoke with the local Acura dealer in Dutchess county and they want $800 for the Aspec suspension and they say it takes 8hrs to install at $95.per hr. labor. WOW..
MrHeeltoe
20
02-23-2023 02:54 PM
MrHeeltoe
09-29-2015 11:43 PM
adreano17
09-29-2015 09:48 AM
MrHeeltoe
09-28-2015 06:43 PM
4drviper
09-23-2015 08:42 PM
Quick Reply: a-spec suspension package..
