A-Spec suspension alignment specs discrepancy
CEO, Team Anthracite
Hey all,
The A-Spec installation PDF states these specifications for alignment:
Fronts:
Camber: - 0 degs 30' +- 30'
Caster: 3 degs 17' +- 45 degs
Toe: 0mm +- 2mm
Rears:
Camber: - 1 deg 00' +- 30'
Caster: N/A
Toe: in 2mm +- 2mm
However, I got a handout from the dealership that says the 04 TL should use these settings:
Front:
Camber: -0 degs 40' +- 30'
Caster: 3 deg 17' +- 45 degs
Toe: 0mm +- 2mm
Rear:
Camber: -1 deg 20' +- 30'
Caster: N/A
Toe: 2mm +- 2mm
Why is there a difference in the camber between these two sheets? Can anyone who's had the A-Spec suspension installed comment on what specs they used?
Fronts:
Toe: 0mm +- 2mm
Rears:
Caster: N/A
Toe: in 2mm +- 2mm
Front:
Toe: 0mm +- 2mm
Rear:
Caster: N/A
Toe: 2mm +- 2mm
Lore, looks like the handout the dealership gave you is for stock suspension, not A-spec. That's why it specifies for more positive camber, front and back. It's just my guess, though.
However, the camber is not adjustable anyway, so you're pretty much stuck to what your car measures on the rack after the suspension install.
Originally Posted by SK7
when you lower you car, you need more negative camber on the rear to help with the cornering.
dsc888
Does anyone else have any feedback about this discrepancy? For those of you with A-Spec suspension kits, what specifications were used to align your wheels?
Factory specs..
Like someone else stated before..you can not adjust camber anyways unless you get a camber kit...otherwise just do it to factory settings. I'll check tomorrow at work to see which is right
I thought camber was adjustable in the fronts?
Lore, have you called another dealership and verified which spec they use?
And both front and back camber are not adjustable.
I just had the dealer installed my aspec suspension kit, and they ran it through the alignment machine, according to the service rep, he said it does align a little more on the negative side because of the lowering of the suspension. I didn't get a read out, but I may go to a tire shop this weekend and run it through an alignment check and see what numbers come up.
Originally Posted by Lore
Hey all,
Fronts:
Toe: 0mm +- 2mm
Rears:
Caster: N/A
Toe: in 2mm +- 2mm
Front:
Toe: 0mm +- 2mm
Rear:
Caster: N/A
Toe: 2mm +- 2mm
Fronts:
Toe: 0mm +- 2mm
Rears:
Caster: N/A
Toe: in 2mm +- 2mm
Front:
Toe: 0mm +- 2mm
Rear:
Caster: N/A
Toe: 2mm +- 2mm
Keep Right Except to Pass
Thanks for this thread. I do not have the A-Spec and have not lowered my car, but when I had it aligned at the dealer this week they claimed that the rear camber was in the "red" range but was unadjustable; the fellow theorized that maybe I had hit a bad bump or pothole. (Which I hadn't.....drove over some very bumpy and pockmarked roads this winter, and some of the streets in DC are always bad, but I hadn't hit anything hard.) I gather that I should not worry about it and should just keep an eye on the tyre wear and rotate regularly. Makes me wonder if his machine was set for an earlier generation TL or something.
I love this forum precisely because of threads like this one.
I'm due for an alignment on my car -- just got new tires and would hate to wear them out prematurely -- and I'm still looking for the new and improved A-Spec suspension alignment specifications.
If anyone has any information, please do share!
Oderint dum metuant.
I've always used the specs listed at the end of the install instructions, and I've never had a problem with uneven tire wear.
I thought the bump stops were only for the stock suspension . Either way, the dealer has never said anything to me about them...guess it's a case of "if it ain't broke..." since I have never had tire wear issues. Still, thought that only applied to the stock set up.
I've loaded my car up once or twice in two years. You're right that the issue was caused with having passengers in the back often or loading down the trunk; however, I still think the fix was only for the stock set up. Check out the SERVICE BULLETIN...the first paragraph on page 2 says the suspension must not be modified and the second paragraph lists other exclusions from the TSB. I take that to mean the problem and fix only apply to the stock coilovers on non-navi 5AT cars. Now, whether that means everyone else is ok or SOL, I have no idea, but I doubt you'll get them to install the bump stops given what it says.
Have you contacted your dealer recently to see what specs they say are for the ASPEC suspension?
emailnatec
29
09-28-2018 04:27 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
4drviper
09-23-2015 07:42 PM
2004, 2005, acura, alignment, aspec, bulletins, proper, rdx, service, specification, specifications, specs, suspension, tl, tsx
