A-Spec Suspension
A-Spec Suspension
How can i alter my A-Spec susepension as i would love the front to be a little bit lower. I went with the A-Spec as i never had a sporty suspension and thought it might be a little to harsh for me but i did wanted some of that look. Well to be honest i love how the A-spec rides and i dont see a problem going a little bit stiffer at all.
Can I just upgrade springs...or maybe just the front as i already have MT A-spec for AT. How would the effect my Shocks ?? I know putting springs on stock susp. would cause premature wear but is that also with a-spec. Im hoping not.
so what would u recommend. If i have to redo the whole thing then for now im not even gonna bother with it...
what would be my best option ??
Here is the way i see it. There are many guys here running 1in to 1.5 in lowering springs on stock shocks and have been for years without any problems. The A-spec shocks are built to take that 1in drop from the springs, so getting aftermarket lowering springs say that lower 1.5 on the aspec shocks would only be putting a .5in of loweing extra on the shock but a full 1.5 on the entire setup.
There should be no problem going as low as 1.75 on the aspecs but will as with anything else that wasnt built for it put more stress but should last you a while.
2016 E350 Sport
It is not clear from your post. Do you have the MT springs installed on your AT? I have this setup. Here is what it will look like with the front about 0.5" lower than the rear using the MT springs. I am happy with the look and ride.
2016 E350 Sport
I have an AT TL-S with MT A-Spec suspension. The rear was lowered abut 0.5" and the front was lowered a little more than 1.0".
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
