A-spec
Team Anthracite Member
BD,
I believe Msnowdon has the MT A-Spec for his A/T TL.... I think he posted that the MT setup drops all 4 corners evenly, rather than the AT setup in which the rear (?) sits a bit lower.
Perhaps he will see this thread and correct me if I have misspoken.
I'm leaning towards the MT A-Spec for my baby... Just looking for the right $$$.
Good luck!
Good luck!
ASPEC Setup
I have that same set up. A-spec MT w/ Comptech RSB in my AT. Scott@Falconi says the spring rate in the MT will lower the front more that the AT and lower the front and back evenly. My guy who did the work told me the car dropped 10 mm (less than 1/2"). Another guy from Honolulu has the same setup. Should be no problem. My TL drives fine with my 19's and no rubbing.
I am running the MT in a AT
LBZTL is correct it evens the corners out, the drive is not that much differn't then the regular suspension.
I had three guys in the car at lunch, and no problem rubbing with a 275/30/19 in the rear.
Michael
Michael
Team Pumkin
Thanks gents!
I'm still debating what suspension setup to go with 18's and to get rid of the fender well gap (or most of it) and it doesn't sound as though the A-spec will do the job no matter which package i buy.
BD
BD
Originally Posted by Big Daddy1
I had a parts guy from Sunnyside inform me the springs for the AT are heavier due the the Trans weight itself.
BD
BD
Team Pumkin
So who if anybody has taken measurements before and after A-spec install to document the amount of drop........some have said 5/8", 3/4" so whats the scoop fellas??
BD
BD
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
4drviper
09-23-2015 07:42 PM
