Someone take a look at my alignment and tell me whats bent?
This is all on stock suspension. My car tracks to the right and steering is vague. Car feels floaty. I have replaced a lot of parts. I'm suspecting my knuckle or subframe but its very hard to visually determine that. Car wasn't in an accident but was towed (most likely damage from that). Why is my camber in the front off and that negative on stock parts?
riding low and steady
Stock camber cant be adjusted, would have to get an aftermarket kit. Hope you got a lifetime alignment. What parts have you replaced? What was the reason the car was towed? Lol sorry for the questions but how and why it got like that would get better answers.
Only way i could see how towing caused it to get out of spec is if it wasnt hooked up correctly to the truck. I guess for anyones future references always request a flatbed if possible.
Talked about this before and only way to know if anything is bent you're going to need to take frame measurements as depicted in the FSM.
Don't know equipment used in "towing" the car, but most would use a wheel lift opposed to the old style strap type and that should not have cause any problems, but with the camber out that slightly, I'd try and shift the subframe to get it back into spec.
emailnatec
29
09-28-2018 04:27 PM
Zonian22
11-14-2015 01:20 PM
