Someone please help answer my staggered question!
Hey guys,
can someone please help me figure out if this setup will work:
CAR:
04 TL
5 AT
Lowered on Tien SS springs (approx 1.4)
Wheels:
I have had this setup and have had no rubbing problems at ALL, now I just want to see if I can have a staggered tire setup.
20x7.5
Offset 42
tires all around 225-35-20
MY QUESTION: can i just put 245-35-20 tires in the rear and just have a staggered tire setup without rubbing? thanks!
CAR:
04 TL
5 AT
Wheels:
20x7.5
Offset 42
VS#03
With that offset.......you won't notice a difference, are you just going with different tires to achieve a staggered look or you are changing the rim to like 20x9.5 in the rear & 20x8.5 in the front with a 35mm thru 38 offset. If you want to staggered......that's what you woulld have to do.
Kevin
Kevin
won't the VSA get thrown off due to different tire speeds?
B A N N E D
You won't have problem with the VSA. I tried putting stock 17" wheels infront and 20" in the rear and VSA worked fine.
There is however no point for you to get a staggered TIRE. First of all if you are doing this purely for looks, then I can tell you a 225 tire infront and a 245 tire in the rear does not look that much different. Secondly, with a wider tire in the rear you would induce more understeer but I doubt this is part of your concern.
Lastly for rubbing, I used to run a 20x8.5" +35mm offset rim with 245/35-20 tires slammed on Tein SS. There was some slight rubbing but it was easily fixed by trimming the rear bumper/A-spec lip.
Do you have the wheels already? With a 20x7.5" +42mm wheel, your new wheels would actually retract 3mm from the fender. If you have the choice, you should get the wheel with a lower offset or get a wider wheel. If you already got the wheel, then you can get some wheel spacers to push the wheels out so it look more flush to the fender.
But like TL310 said, if you want a staggered look, then get wider rims in the back.
'06 750Li Sapphire/Creme
I think the ONLY reason some of the guys on here are "going staggered" is simply to get the wider lip in the rear of the car (so that it "looks" like a BMW or other rear wheel drive car). No offense intended but putting wider TIRES in the rear does not do that for you. You would not notice the difference from the side or front or rear. The ONLY time you would notice the wider rear tires is from the 30 or 60 degree angles and nobody is really looking that hard at the car from those angles to give you any credit for the effort. Additionally, the wider tires in the rear will actually HURT the driving characteristics of the car thereby making it even LESS desirable. Some of the guys are willing to sacrafice the driving characteristics to get the wide lip but I don't think there is a TL owner on here who would be willing to give up the handling just for some wider tires WITHOUT the lip.
^^^^^ what he said!
BORICUA
Hey guys same here. I'm about to get a set of Sevas wheels in 20's, staggered. Now the rear wheels I think are 20x10. Is that going to be too big or can I correct that with the offset of the wheel? Any suggestions will help a lot. Thanks
Originally Posted by ndabunka
Michael - This has been covered in this sub-forum a number of times. 20x0's are doable but depending on the actual sized tire it may take work, may not work at all or may not be a problem. Do a search for all of K-Shawn's prior post and get yourself an education...oh yea, and learn to use the search button...
why would you want the staggered look on a TL anyway? Anyone who knows a little something about acuras would know that they're FWD and that the staggered look is completely useless and actually hampers the car's performance... there's also a good chance they'd laugh at you if they realized what kind of look you were going for... especially with only staggered tires...
not vtech... VTEC!!!
Some people are willing to sacrifice handling for that RWD look. They might impress kids in high school but they are just jokes for for people who really know cars.
Whatever floats your boat!
BORICUA
BORICUA
ow can you get a staggered look when the size of the lip is the same on every wheel?
VS#03
Kevin
canyon carving on bald tires is the best, I used to have to pay to have my new tires shaved
HEHE!!
first of all... SSR's are brand new. 2nd of all... got these set of GS-D3 for a great deal and just want to see how they handle. And yes... they handle really well. Thanks for caring.
Hey, tires are used... but at least I stayed far away from GHETTO!
Staggered on a FWD =
VS#03
HEHE!!
Kevin
VS#03
HEHE!!
Kevin
lol!! it's so easy to push your buttons....
I tried to ignore your previous post and try to let bygones be bygones.. but I guess it's too complicated for you to understand.
Try to relax and stop calling people faggots... Remember that military father guy from "american beauty"??
and yes I will be at HIN... drop by and say hi!
VS#03
Kevin
Originally Posted by K-Shawn
Yeah.......I will be there with my crew, matter a fact I will stop by to see hello......so we can put a face to the name.
Kevin
Kevin
Regions Leader
Regions Leader
Its funny to me how you two always seem to start shit. Not just with each other either but with everyone. You both always get so mad so fast. You guys really need to take a step back and ask yourselves how much you enjoy being on this site.
Now you're going to meet up? hope you guys can handle it like adults....
wdp skyhawk
do staggered rims just staggering the tires won't give you that look you crave just go with a 20x8.5 all the way around with a 255-30-20 it will look wide and aggresive and your car will still handle great
BORICUA
Kevin
Kevin
VS#03
I've been searching for this for days now and I can't find a direct answer. Some one here told me you may know the answer. Ok I know you're running on 20x10 with an offset of 35mm, does that means that if I do 20x10 with 40mm my wheel will be more toward the inside of the fender or more to the outside. Please help me here so I can buy my wheels. Thanks
BORICUA
If you're going to run 20x10s........you have to use a 35mm offset, here's a picture of the 20x10s from the rear.
Michael - 40 will push the outside of the wheel more towards the center of the car (Inward). Therefore, it may also "scrap" on the suspension. Try it and let us know how it goes. Some guys on here have added 5mm spacers. You could do that and then you would have the same (adjusted) offset as K-Shawn
BORICUA
BORICUA
Originally Posted by nowucme
I run 20x8.5 in front with 20x10 in rear. I don't rub and really like the stagger look.I have not had any problems and don't notice any difference in the handling of my car.Just test fit first.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
Eggs999bacon
09-24-2015 10:08 AM
