slammed the TL have a couple questions.
Honda / Acura Fanboy
Stock rear toe if its off will the car wobble certain speeds on take off not always or certain like road condition.
also the front upper control arms are hitting i believe what's a way around that should I go hacking down there in my wheel well? Im more concerned about the wobble. and i did alignment but no camber or anything everything is stock suspension i believe he said the rear toe is off can that be the cause for the wobble?
Toe off means major wear on tires . Posting an alignment sheet will help !
UCA's hitting chassis. But more worried about a wobble. Unique AF. I respect you.
A wobble isn't very descriptive, though. As others have said, it could be your axles if you mean a wobble on acceleration. Or are you refering to bump steer? But...yes...you certainly need an alignment.
