Should I get coilovers?
Before I ask my question, I just want to say that I'm new here. So please let me know if I put this in the wrong spot. Oh, and thanks in advance for any help that I might get.
So, I'm looking to pick up an 04-05 TL in the next month or so. Along with a list of other things that I want to do to the car, I want to lower a little bit. However, I only to drop it by about 1 inch. No lower than 1.5 inches.
With that being said, would I be fine with just putting lowering springs on OEM struts or would I be better off just shelling out the extra cash to get some coilovers?
Again, thanks for anyone that helps me out. I'll probably be back with other questions as I come across things that I want to do to it.
No need for coil-overs when all you want is a 1" drop, there are plenty of springs that can do that for you. Coil-overs are for people that want complete control over every mm of ride height. Many times this is because of the wheel/tire combo that they want, same reason they get camber kits. You don't sound like you need that, and the extra money could be spent in other areas. If you decide later on that you really want coil-overs, then you can recoup probably 50% of your money from the springs, there's always some new guy that only wants a 1" drop
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
As long as I'm not going to be hurting my OEM struts by dropping it an inch (which my understanding is I shouldn't be) then I'm a happy camper.
You're just mod-happy. Coil-overs do not suit his needs, if his struts are shot it changes the plan just slightly, but not to coil-overs.
That would still be tons cheaper than coilovers.
![](https://farm1.staticflickr.com/334/19643450952_c033514b7c_b.jpg)
Perfect. by Andrew Thompson, on Flickr
Former Sponsor
I would say going with a set of coilovers isn't even "jumping the gun" considering they can often cost less than a spring/shock combo and be easier to install. Check out the Street Basis we have on sale for $531.
TEIN Dampers - Street Basis - Excelerate Performance - Japanese and European Performance Specialists!!
With that being said, I am more open to getting a "cheaper" set of coilovers. I don't need (or really want) racing grade stuff. Since it would be a daily driver I want something that is still a bit stiffer than stock, but not so stiff it would become uncomfortable on 1-2+ hour drive.
Would I really benefit from having damping control with the Tein Street Advance or does the Street Basis fit my description?
Former Sponsor
It sounds to me like the Street Basis would fit your needs perfectly. They are sportier than the oem suspension without sacrificing ride quality for a 1 or 2 hour drive. You can see reviews on this forum from others who have been using the Basis and have very positive reviews. I wouldn't recommend the Street Basis for the track as they don't have much adjustability, but they are great if you are looking to lower your daily driver.
Well, my plans for getting the car have changed a little bit. I probably won't be picking one up for another couple of months, but in that time I'll be able to get some more money together.
ExcelerateRep (10-05-2015)
OP i couldn't write you back since your private messages are full (i think new members only get 1 saved, or 2)...but here is what i wrote back:
"oh didn't know you didn't have the car haha. i'll be putting them up for sale soon but just hit me up when the time comes if you're still interested.
good luck on the car search, it's a solid car and i've been the original owner of mine (2008 Acura TL Type S...7 years!). if you have any general questions just let me know, i've torn my car apart many times and know most of the highs and lows of the car"
Right now it is just a lot of research to see what tends to go bad on these cars so I know what to look out for and what I want to do to it when I finally get it.
Former Sponsor
The deals we have been approving on Tein parts on our Custom Pricing Quote page have been pretty good indeed...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
