Serious Alignment Problem
Old 10-19-2010, 03:09 PM
Coal
05TLdcc's Avatar
Exclamation Serious Alignment Problem
Ok so I have extreme feathering on my front two tires from the toe. I took it to a trusted shop and they told me that actually my toe, camber, and caster are perfect within the set guidelines for our cars.
The weird thing is that my right rear had a .37 toe and my total toe it .34
Does this have anything to do with the fronts? I'm super confused because my rear tires are wearing perfectly and the fronts are shot.
Im super confused thanks for your input guys!!!
Old 10-19-2010, 03:22 PM
Coal
05TLdcc's Avatar
Measurements
Old 10-19-2010, 03:23 PM
Received 16,267 Likes on 11,974 Posts
Cole, the fuck have you been doing to your car!?!?!
I keed, i keed. Hope everything works out for you.
Old 10-19-2010, 03:32 PM
Coal
05TLdcc's Avatar
i have no idea! only 6000 on the fronts and theyre shot. ugh thanks tho man! hopefully ill see ya at the next meet
Old 10-19-2010, 03:50 PM
Coal
05TLdcc's Avatar
Mods can we put this in the main forum so i can have more exposure? it's a bit of an emergency.
Old 10-19-2010, 05:35 PM
NAiL05's Avatar
Your front toe looks fine. As for your rear left toe thats off quite a bit. Toe itself is the main wearing part of the alignment. Camber wears but not as bad. Is this pre alignment because the left side doesnt even look adjusted at all. Looks like you hit something lol.
Old 10-19-2010, 06:35 PM
B A N N E D
friesm2000's Avatar
remember the right side is negetive, so it would be 0.35, but you have to think about this is that the alignment machine is reading more precise then what is visable, and all it is doing is rounding off the numbers, which just so happens to be 0.01 more then what you are reading
then is that a hunter machine too???
and as far as the tire wear issues, is EVERYTHING tight in the front end, cause remember the machine is only reading the static alignment, and not the dynamic, as if the car is rolling down the road (and it is best to check the suspension in a loaded state too, basically jacked up underneth the control arms, so it is as if the car is still sitting on the tires themselves
then can the shop also print you out the other specs too, such as the SAI, included angles, kingpin inclination
Old 10-19-2010, 06:45 PM
Coal
05TLdcc's Avatar
lol thats what i said when i got the piece of paper but i know i didnt hit anything unless my mom did when she drove it.
if my front toe is fine why did i burn tires in 9000 miles? thats what im stuck on
but thats obviously way out whack. plus it really confuses me on my front toe wear.
Old 10-19-2010, 06:47 PM
Coal
05TLdcc's Avatar
i have no idea what machine it was. So what your saying is that i need to check my struts and my bearings?
Old 10-19-2010, 07:00 PM
B A N N E D
friesm2000's Avatar
struts LMFAO, they have no effect on the alignment on our cars (since we have a upper control arm for that purpose )
but basically yes the suspension and such needs to be checked out for play and such (tie rods, ball joints, bearing, bushings, etc.)(the play would be allowing the alignment to be changing as you are driving down the road)
btw is the steering wheel level and does the car track straight down the road (there is a possibility that both sides have play in it, still allowing the wheel to be level though)
and the printout just looks like a hunter machine printout, why i ask
Old 10-19-2010, 07:05 PM
Coal
05TLdcc's Avatar
lol sorry im a n00b. alright thanks! i will have my guy check all that out. the steering wheel is level and has no give. the car will sit straight forever as long as there aren't and bumps in the road or anything. luckily we have a few roads that are smooth as glass around here.
Old 10-19-2010, 07:10 PM
Turbonut's Avatar
Tires ever been rotated, front to back?
Old 10-19-2010, 07:12 PM
B A N N E D
friesm2000's Avatar
, our "smooth" roads still have washboard on them or are too curvy to ever check an alignment (but sometimes curves are good though, in that you can check how the car handles on them though )
Coal
05TLdcc's Avatar
yes about 4500 ago. see the weird thing is this happened over such a short period of time i had no chance to find it early.
Old 10-19-2010, 07:14 PM
B A N N E D
friesm2000's Avatar
6000 miles and tires should not be shot, shit people do that all the time for a rotating interval
Old 10-19-2010, 07:18 PM
Coal
05TLdcc's Avatar
yeah we got some good roads
well ive called around and found a race car shop, thats what i would call it even tho it make me feel like im five, with a super precise equipment for 100 bucks. hopefully they can tell me whats truely wrong with it
Old 10-19-2010, 07:20 PM
B A N N E D
friesm2000's Avatar
also before going any further why type of tires where they, for an idea of the wear characteristics of those particular tires
and btw i did burn through a set of all seasons in like 12,000 miles, but then again i did do a couple of burn outs on them though, so not really surprised on that though (but they do not have the feathering though, just bad camber wear, especially when you put like 1.3 degrees of camber on them)
Old 10-19-2010, 07:22 PM
B A N N E D
friesm2000's Avatar
and most roads here have pot holes and such (or have such bad ruts from wear and tear, it just is like a skating rink when the snow freezes in those ruts)
try aligning an audi after tie rod replacement, something like 2+ hours (so $200 or so) to properly align, cause you gotta set bumpsteer also
Coal
05TLdcc's Avatar
Falken FK452, they're awesome tires because they grip well and are quiet. but maybe no life span
Old 10-19-2010, 07:28 PM
Coal
05TLdcc's Avatar
yep i'll pass
NAiL05's Avatar
As people mentioned make sure the suspension is still inline. If they are directional are they mounted or were they rotated the proper way? I have seen people fuck that up and it eats through tires like hell. Also driving styles would be nice.
Old 10-19-2010, 07:30 PM
B A N N E D
friesm2000's Avatar
yeah geneally i would not consider a falken as a higher end tire (but they should still be lasting longer though)
and i do not see a tread wear warranty on them yet, but i see a tread ware rating of 300, so they should at least last 20k if not around 30k (basically just add two 0's to the rating for tread life, it is VERY general though, and some brands are better then others though)
Old 10-19-2010, 07:31 PM
Coal
05TLdcc's Avatar
yes they are directional and yes they were rotated properly because i did them lol. back to front and visa versa.
driving style = well im 18. is that enough lol?
no i normally drive conservatively unless im on an empty back road with lots of curves
Old 10-19-2010, 07:35 PM
Coal
05TLdcc's Avatar
hm interesting, what would you consider to be a high end tire?
Old 10-19-2010, 07:39 PM
B A N N E D
friesm2000's Avatar
like a bridgestone potenza or Michelin pilot sport (think more like ones that you would see on a higher end cars), but don't get me wrong they do not come cheap
Old 10-19-2010, 07:48 PM
NAiL05's Avatar
That would explain the life of the tires. Curvy roads put a lot of stress on fwd vehicles. You have the braking, driving, turning all done by the fronts. That puts a lot of stress on the front tires causing them to heat up and wear quicker than normal.
Old 10-19-2010, 08:05 PM
Coal
05TLdcc's Avatar
hm well i probably couldn't afford those lol
why couldn't acura make the TL rwd
Old 10-20-2010, 08:24 AM
Coal
05TLdcc's Avatar
Ok so update:
Apparently the last guy i took my car to to get an alignment didnt install and/or took out and never replaced the "ez arm" that goes on our rear suspension that adjusts camber.
I didnt even know this existed until the morning.
any facts on what an "ez arm" does/is would be great.
TYIA
Old 10-20-2010, 11:51 AM
Turbonut's Avatar
As there is no camber adjustment available on the TL from the factory, you would need an aftermarket unit installed.
Old 10-20-2010, 02:26 PM
Coal
05TLdcc's Avatar
ok that makes a lot more sense. just bought four new tires and getting a reputable alignment shop to do the alignment tomorrow morning.
thanks for the help guys gotta love the forum
Old 10-20-2010, 05:35 PM
B A N N E D
friesm2000's Avatar
that "ez arm" do you mean this...
http://www.spcalignment.com/PROD_DIR...d2=67095&cmd3=
or this...
http://www.ingallseng.com/38725-smar...-bushings.html
but as said camber is not adjustable from the factory though
Old 10-20-2010, 07:26 PM
Coal
05TLdcc's Avatar
or this...
numero uno! yeah. well my mom wants me to call the dealer, but yeeeaah that probably is not useful. idk tho maybe they can help me
Old 10-20-2010, 07:34 PM
Coal
05TLdcc's Avatar
Oh and Friesm2000 thanks for being so helpful, your helping me out a lot
Old 10-20-2010, 07:53 PM
You better hurry up, the Galveston meet is around the corner.
Old 10-20-2010, 09:18 PM
Coal
05TLdcc's Avatar
i'm pretty sure i'll have it done, i almost have this problem under control.
.......hopefully
Old 10-20-2010, 10:18 PM
B A N N E D
friesm2000's Avatar
if modified alot of times dealer has issues with touching it (let alone having "issues" with being able to adjust those components), can't complain though, since they do like stock cars
and btw those ingall ones are the easier of the two to adjust
Old 10-20-2010, 10:40 PM
.......hopefully
T minus 11 days
Hope you get it, bro.
Old 10-21-2010, 07:01 PM
06 Anthracite TL
erdoc48's Avatar
I have one question...as the toe is the only adjustment available in alignment without any aftermarket upgrades, how many miles do you have on the car, and has the shop investigated the car for any damage or looseness in the suspension parts? I'd hate to see you get a new set of tires, a fresh alignment, and have them wear only after 6000 miles again.
Old 10-21-2010, 11:00 PM
Coal
05TLdcc's Avatar
yes the shop did look at the entire suspension, said i had normal wear and tear. and i have 75 thousand in the car, so that being said im not positive what that means. I'm taking the car to a dealer tomorrow to see what they say, im not going to tell them anything so i see what they say, i just dont want them to BS me
Old 10-21-2010, 11:14 PM
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
I have one question...as the toe is the only adjustment available in alignment without any aftermarket upgrades, .....
I believe front (only front) Caster is also adjustable stock.
Edit: OP, I don't see that your front tire wear is realted to your alignment, assuming the sheet you posted is good (i.e. the machine was porperly set up/calibrated).
I did not see in the thread (scanned it, so I might've missed it), but have you had your tires rotated? Is it possible you feathered them on the rear and then moved them to the front?
Quick Reply: Serious Alignment Problem
