Rotate Wheels
Eagle Automotive, Inc.
Rotate Wheels
The dealership said the car will tell my when to rotate my tires but I rotated them before I knew that so I was trying to find out how to reset the tire rotation on the computer (like you would when you change the oil) otherwise how would it know I rotated the tires?
Next question my readings on the computer about the tire air pressure, are they in the correct postion or are they now displayed backwards (in the display) now that I rotated the tires?
Oderint dum metuant.
Don't worry about the tire rotation per the MID; just rotate them as needed. Besides, you can't reset just part of the maintenance minder. If you want to follow the MID 100%, just rotate them again when it calls for it and follow the MID from that point forward...it won't hurt a thing to rotate them again that soon.
The pressures are where the tires are; they are in the correct position.
Fightin' Texas Aggie
When the MID gives you the maintenance due notice, it will give you a code. You then look up the code in the owner's manual and it tells you what maintenance to perform. The tire rotation usually goes along with the oil change. Something like A1 or A2, I can't remember which one it is. There is no separate tire rotation notice.
06 TL 6spd. Navi/A-spec
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
