RonJon Inspyre vs. Acura A-Specs
Anyone know how much the a-specs weigh? I believe there was some sort of thread on it...27.4lbs each wheel for the a-specs? Ron told me the 8.5 patterns weighed about 27lbs each...black raven; those they 19s right?
I'm assuming both of these are without wheels? Heavier rims = a slower car???
thanks,
thanks,
The weights are for just the rim. Yes, heavier rims=slower car. You probably wouldn't notice it but who knows. For an 18 inch rim, 27 pounds is pretty heavy. If you don't mind a slightly harsher ride then go for the 19 inch inspyres, but beware of potholes.
Inspyres are pure sex.
The rule of thumb drag racers use is 5 lbs of wheel weight (per wheel) = 200 lbs or 1/10th second in the 1/4 mile. A heavier wheel also increases unsprung weight, which affects steering response and turn in.
Originally Posted by MWalsh9152
I just weighed my 8.5" a spec and its 27 lbs
also figured: since i'm already riding pretty low, the 19s may not fit, but in fact need a raise? eh well...a-specs look SICK! hahai'm happy with my purchase...
Originally Posted by allstarsquad
whats a good site to purchase a spec kit im trying to get 1 asap
all work and no play
Time to Climb
check out www.wheelweights.net
nuldabz
09-03-2015 05:49 PM
