Revised rear toe in specs
Old 03-01-2008 | 11:26 PM
Jesstzn's Avatar
Does anyone have the link to the TSB that shows the revised rear toe in specs to reduce rear inner tire wear?
I did a search and couldn't find it .. I thought I had it book marked.
Old 03-01-2008 | 11:48 PM
Fulani has a TL's Avatar
I just got the ingalls camber put in like 2 weeks ago. Looking at the sheet, the specificed range for 04-07 TL is -.08 to .08 for each side.
Camber range is -1.5 to -0.5
hope that helps
Old 03-02-2008 | 08:58 AM
Jesstzn's Avatar
I think there was a TSB or something that revised the toe in for the rear to "0" and I wanted to be able to print it and give it to the alignment shop so they didn't do the 2mm +/- etc.
Old 03-02-2008 | 09:06 AM
Bearcat94's Avatar
AZ Community Team
Here is the link to the TSB's:
https://acurazine.com/forums/showthread.php?t=154245
I think this is the one you're looking for:
http://www.in.honda.com/Rjanisis/pubs/SB/B05-076.PDF
Dunnik
09-15-2015 11:52 PM
obsessedmotors
09-10-2015 10:49 AM
Quick Reply: Revised rear toe in specs
