Replica TL-S wheels....a few months later
#41
^^^ +1. I noticed my 06 auto's acceleration was a bit slower after I threw on my type-s reps. I didn't think my TL could get any slower. I was wrong lol. These reps are HEAVY. Save your $ and refinish your OEM type-s wheels or look into getting some light weight aftermarket 18's.
#42
The car being slower is def in your head
They are not heavier I had the Type S reps and oem wheels in storage at the same time and they are the same weight. both too heavy to be 17" wheels.
my 19" wheels weight 1lbs less.
I did get a great deal when I ordered these wheels cause the seller sent me 6 by mistake . I do wish they made them a shade lighter I think they are a little too dark
#43
Looks like these reps are back on ebay. These are the ones from tobacco road. The exact same ones I have. Here is a link: 17" 17x8 Type s Style Alloy Wheels Rims for 2004 2005 2006 2007 2008 Acura TL | eBay
And here is what they will look like
#44
2004 NBP TL 6MT
Does anyone know if these Ebay TL Type S replica rims 17x8 clear the TL 6MT brembo front calipers?
Please PM or post photos if you have some showing this.
Thank you. I'm currently looking for a 2nd set of rims for my 04 TL 6MT.
#46
2004 NBP TL 6MT
Well, one would think to agree with you. However, I recently ordered other TL replica rims and they advertised and stamped on rim with factory specifications you mentioned and interfered with my front Brembo calipers.
I want personal experience with the product on Brembo calipers please.
#47
#48
2004 NBP TL 6MT
Yes, I agree with you.
However, it doesn't fix the fact it was advertised online and stamped on rim as 45mm offset. Exactly why I want personal experience with this particular product to verify someone with brembos has no interference issues. To be more clear, even if they are 45mm offset at the hub, my issue was not at the hub, but backface of the spokes that rubbed the caliper. They were 04-06 TL fat-five spoke rim style replicas.
#49
2004 NBP TL 6MT
Ended up purchasing these Type S replica rims and they DO clear factory Brembo front calipers by about the same factory clearance as my stock 5-spoke rims. I have a 2004 TL 6MT.
I purchased these Type S rims from the same mentioned Ebay seller. The previous replacement 5-spoke silver rims I purchased from Wheels & Caps, that did NOT clear my Brembos and most likely will work on automatics. What is interesting is that both sellers are the same source and Ebay seller is cheaper.
#50
Did anyone actually weigh the replica's vs the OEM's? I read a bunch of talk about it in this thread about people saying they were going to do it but no one did. Anyone know the exact weight difference?
#51
I have 3 original (base model) wheels and one replica. The replica is about 3mm or so closer to the caliper because the spokes are fatter.
I use the (Acura genuine) waffles for summer with summer tyres.
My application is a TSX with Advics 4 piston brakes...so I cannot use the replica wheel on the front because you can only barely get fingernail between the wheel and caliper. But I imagine they'd be OK with the skinnier Brembos.
My replica weighs a LOT more than my originals.
#52
Well that is some new info about the replicas having a fatter spoke. I also learned the factory TL-S wheels are made by Enkei too.
I researched via google even some more and it is funny because the people that have been posting the weight are weighing it with the tire mounted. Tires sizes,the wear on the tire, the model of the tire, and the air pressure in the tire will effect the weight and can vary crazy.
But so far I have read that the stock 07-08 Acura 17x8 wheel weighs between 22-26lbs. One guy posted saying he messaged a seller of the reproduction TL-S wheel and it weighs 29lbs.
#53
I can weigh mine...with the same brand of tyre, and same tread wear. unfortunately, its still not clinical, as each tyre may have small differences in weights due to manufacturing tolerances.
Plus they have different amount of wheel weights and road crud on them, if we're getting down to brass tacks.
2-4LB differences in a 17" aluminum wheel is quite large. Aluminum weighs like 0.098ish LB per cu.in.
A 4LB block of aluminum is roughly 40cu.in. Imagine it as a block thats 1" wide X 5" high X 8" long. That's a lot of GD aluminum.
#54
Lotus 240R CUP 6 by Andrew Thompson, on Flickr
#55
"Impossibly heavy" I don't think so for a car that weighs over 3600lbs. Your 4 lug sports car that was built to be lightweight of course will have super lightweight wheels. Thanks for contributing and going off topic. /sarcasm.
#56
Doesn't matter what the weight of the car is, 22-26 lbs is terrible. Unsprung weight is always important, and if you're putting special wheels on a car as an addition to a package that has an obvious sporty nature, why have such a heavy wheel? No reason these wheels couldn't be forged and 18 lbs, other than the Type-S isn't really a sporty car, it's just made to look like one.
#57
Lol...well...there's a big difference in price between forged and cast wheels.
Lots of sports/sporty cars come with cast wheels. Why would the added cost of a forged wheel benefit a car like the TL in enough of a way to justify cost?
Is your bombshell claim that the TL isn't as focused as a Lotus?! :gasp:
#58
#59
Well according to Honda Acura it wasn't so terrible. You should look up similar cars in the same class and their factory wheels. Hell look at the small VW MK4 GTI, the 20th Anv's had 18'' wheels that were a whopping 32lbs each. Yes a lightweight wheel is nice to have and does help in a car that is raced regularly. But it wasn't on Honda Acuras mind to mass produce a 15lb~ 17x8 wheel for a factory 4 door luxury vehicle that most came equipped with an automatic transmission.
First, I don't care about VW, I'm talking about Acura. A 32 lb wheel on such a small car would be absolute stupidity.
Second, Acura doesn't make wheels, they are all contracted out. The difference in weight comes in the process of making the wheel, like the specific type of casting or forging, and style of the wheel (the amount of material). I'll give it to you that there is no need for a 17 lb forged wheel on an Acura TL, but I'm certain a flow-formed cast wheel would have been a negligible cost increase, but would have given the car a much better steering feel, increasing the sporty nature of the car. Or even better, they could have kept the same feel and increased the front camber, which would have produced better numbers. Either way, lighter wheels are not only for racing. In fact, many forged racing wheels are heavier than their forged street counterparts because they are made stronger to endure the rigors of racing. My Lotus forged Cup 240R wheels are this way, compared to my OEM forged LSS wheels.
I'm not going to continue arguing with either of you, I realize there isn't an outright need for a light wheel on the standard TL, but given the sporty nature of the TL-S, and in fact the company itself, I feel like the wheels should have been lighter.
#60
Acura has never used forged wheels, except on the NSX.
nissan/infiniti top trims come with forged wheels, but they also compromise on shit like interior materials that seemingly don't last as long. Why you are criticizing Acura for not putting sport wheels on a non-sport, fwd sedan, and chose to focus on things like the interior lasting longer, is beyond me.
it all comes down to price, which is ultimately handed down to the consumer, at a marked up rate.
TacoBello (03-12-2017)
#62
Fortunately, there's nothing to debate. Many manufacturers never use forged wheels, unless they are on their most sportiest offerings. Even then, they only started to become a bit more common place in the last 7-8 years.
The people who even bought the TL-S brand new in 07-08, were predominantly buying a nice sedan, and secondary was its sportiness. If given the option, I'm willing to bet most would opt out of getting forged wheels, if they raised the price of the car by 3,000 bucks (or more).
#63
And I never suggested that they use forged wheels in this application. Reading comprehension: you're missing it.
Same answer as above.
No it doesn't, it comes down to who they made the deal with and for how long. In this case, Enkei.
These comments prove you're pretty lost. If they didn't want a sportier car, then why didn't they opt for the base? I'm interested, because, you know, I actually bought my TL new in 2007. Secondly, you're completely lost if you think that forged wheels cost $3000.
#64
I'll be the points keeper here.
Undeniable alternative facts offered for debate:
-Forged wheels don't cost ~$3000.
-Forged or flow formed lightweight wheels DEFINE a more sporty version of a base model. If it doesn't have forged/roll forged wheels, then its just not worth it to upgrade from base. Examples of cars like VW GTi's are NOT useable as a counterpoint to this point.
Good luck, Taco Bello.
#65
I'm saying 3000 bucks, the cost to the manufacturer. Actually, I just looked up the OEM 19x9.5 and 19x10.5 370z Nismo Rays (fucking huge wheels) and they are just under $2100 US for the set, online, from a Nissan OEM parts site. That's the cost to the consumer. So what does Nissan pay when they mass order these, for the factory? A thousand bucks a set?
yes, the TL-S is obviously the more sporty model, however, most of them were purchased with the meh 5AT, in comparison to the much more "hell yeah" 6MT. I mean, the base 04-06 6MT is as fast as the 07-08 Type S 5AT I think the market spoke for itself as to what it valued more. Yes, there are those of us who would like features like that- myself included- but not everyone is willing to pay for it, so Acura toned it down to the point where people would pay the extra for them.
Acura was also in a position where they wanted to keep 3G TL sales up as much as they could, since it started out really strong. The car was a hit in its early years and Acura wanted to exploit it some more. Hence they build a car for the masses, where the average person didn't want a true race car whatsoever. It may have only raised the price $500 at the end of the day, but I'm sure their market analysis told them it's not worth it. But then again, you can say that about a lot of things, in a lot of different cars. How often have you said or have you heard someone else say "well if only _______ did this to the ________. Sadly, it just comes down to dollars and cents.
I dont one think it's that far fetched at all. Also, as I said earlier- forged wheels are more common these days also, then they were in 07. Yeah, there were cars that had them. But there's definitely more today, then back then.
#67
You know the A-Spec wheels that everyone on this board likes so much? Those wheels cost DEALERS $62 a wheel 1 year ago, I literally have the invoice. What's important about that is not what they cost the dealer, but what they must have cost the manufacturer. I don't know that figure, probably no one knows, but we can guess it's at least under $62.
Back when I worked for Honda I saw this all the time, but a better example might be the BBS wheels that came on my 2005 STi. This was a forged wheel that cost the manufacturer $22 a wheel (it's all over the place in the rally world). What's important about that figure? BBS didn't make nearly the wheels for Subaru that they have for Honda/Acura.
So, in short, you are right that a forged wheel would have probably cost HMC more money, but not in the ballpark you're thinking.
But let me state YET AGAIN that I did not say that Acura should have put a forged wheel on the TL-S, I simply said that 22-26 lbs is very heavy for a wheel on a sporty version of the car, and Acura could have easily put an 18-lb flow-formed cast wheel on the car and made the driving-feel much better. Most guys on this board will never figure this out because they are either stancing the hell out of the car and stretching the tire, or like myself and trying to get that M5 look with a 295 tire...both of which degrade driving feel. It is what it is.
#69
#70
Drum roll please.... The factory OEM Acura TL-S wheel weighs 23.139lbs. Sounds legit to me.
I ended up just buying some anthracite metallic touch up paint for $12 to touch up the curb rash from the previous original owner. I also emailed a seller selling the knock offs and to find out how much they weigh which is a supposed 29lbs.
#72
#73
Much heavier than my stock combo IIRC, though I don't have the numbers in front of me at the moment. I have a base, not at TL-S. The unsprung weight isn't unbearable, though I can certainly feel the difference, but if I wanted the car to have a sportier feel I would have definitely changed to a lighter combo.
#74
I guess I don't quite understand.
You're saying Acura should have used roll forging on the stock wheels to make them lighter...because that improves all kinds of suspension feel and because its a sporty version of the base car.
But you then used a heavier wheels/tyre (combo) than stock, in order to make your car more sporty....or to improve appearance without caring about the negative effects of using heavier rollers?
But...Acura should have made lighter wheels even though you yourself would chuck them anyway in favour of heavier ones?
#75
I don't know how much clearer I can be on this point. In my opinion, when releasing a sportier version of the base TL, Acura could have done some things differently and made the car more fun to drive. One of those things would have been a lighter, and more performance-oriented wheel/tire combo. Yet they did not do this, what they did was add unsprung weight to the TL-S over the base car, which makes exactly no sense whatsoever.
#76
Is there a post I missed that says that the base model wheels are lighter? That. wasn't your original point...
So why did you make yours heavier to make it more fun to drive?
Do you think that maybe Acura looked at their demographic and said "meh, the wheel weight probably doesn't make enough difference to justify costs. lets make other, more effective aspects of the car more sporty"?
You're the one that compared the TL wheel weight to that of your Lotus. We get it. You have a Lotus. Now you're saying that comparison is not relevant because the TL doesn't really need to have all that driving feel. If you needed driving feel, you'd drive your Lotus.
In fact, you say you changed to heavier wheels because the important thing about your TL ride quality (???!?!?)
But Acura shoulda made lighter wheels still tho. To improve performance. Even though its not important. And if you wanted a focused car, you'd buy a Lotus.
#77
#78
Yeah that would of been nice and I agree. I do wish it had a lighter wheel. That is what the aftermarket is for. Maybe it was during the time frame of the car being produced during the recession and all and the crowd it was attracting. At $40k mainly older middle age guys that were more concerned over the looks, Slightly bigger brakes, ground effects kit, a cool looking exhaust, a bunch of standard interior electronics and other eye candy to get the consumer to pay the premium. I am sure if there was a market for it they could of had another trim that was focused on being lighter with even more power and only came standard with a manual transmission with 1000 made or so.
The factory waffle wheel looks so damn good and I don't really plan on getting a lighter aftermarket wheel anytime soon. I went down that road with a prior vehicle I had. A Neon SRT-4. Bought a set of 17x7 Konig Daylites. They weighed 14.5lbs each and were under $120 a piece. Prior to those I was running the factory SRT-4 BBS ACR wheels which were 16x7 and weighed 18lbs each. A lighter wheel does help all around, less rotational mass for the win. Car felt a bit different, but I was not a professionally driver that actually road-coursed regularly to feel the difference. But for a daily at the time not so much.
I drive 16 miles each way to work and I too enjoy a nice smooth ride for my daily. I removed the spare tire and the hardware to help a tiny bit for weight savings.Don't plan on doing much other than that since it is a 3600lb behemoth. But to todays standard that is normal for that type of vehicle.
#80
Got an email back from a seller selling the reproduction TL-S wheels. Was told they are "approx. 22-23lbs each" Not sure about that one
