Recommended tire size for 8.5 A-specs
If you want my opinion, id try to stay close to Factory overall tire height. that way your speedo is not thrown off. factory tire size is 235/45/17 on a base. and in theory for every inch you go up on rims, u go down 5mm so 235/40/18 would be the size. unless you want to get a wider look.
http://www.miata.net/garage/tirecalc.html
play around with sizes on this site.
Chad05TL (08-13-2021)
I had 245s before my current 235s. I couldn't tell a difference when driving there's barely a visual difference.
245s:
235s:
245s:
235s:
I put 245 on mine. I like the look of the sidewalls better on the 245 vs the 235... Also, you aint gonna get any extra-rim protection... Believe me, my wife proved it to me in the parking garage at her work
I have 245's on mine as well (well- not at the moment- the 8.5's are in the garage)
245s are looking sexy!
Stay Out Of the Left Lane
Received 1,236 Likes
I've got 255/40 Michelin Pilot Super Sports on mine and love them -
I took some more pictures of the 235s. I love the look of the 255s but I would rub in the back.
Stupid rock
Dat heavy edit
Honestly I think A-Specs look great no matter the tire width. I've run both 235 and 245 with no issues.
Stupid rock
Dat heavy edit
got to bring back an old thread!
so its time for me to replace my tires...i had a flat today....
I currently have conti extreme contact DWS 245/40ZR18.... I want a bigger sidewall...i have had several blowouts by hitting potholes...can I put 245/50zr18's on the 18x8.5 aspecs??
FYI I have factory 6-speed suspension (not aspec)
thanks for your help
JORTS (06-09-2014)
@JORTS
I had several tire fitted to my aspec 8.0 and most of them have little stretch with 235. You can see the lip exposed and I hate that bullshit. Factory size my ass. Next time I would go with 245.
For 8.5, I personally would go 255/40. If any issue with rubbing then roll the fender.
NBP04TL4ME (06-10-2014)
As I mentioned above - I have 255/40 Michelin Super Sports on my 8.5" A-Specs and have no rubbing. Caveat is suspension is completely stock.
Thread revival
I’m sure someone might know. I was able to find a pair of the 8.5 Aspec’s and I was wondering if a 265/35/18 tire will fit on them and not rub if I’m still on stock suspension. I know they are the same diameter as the stock wheels so my speedo will stay correct but I’m concerned about rubbing.
https://www.google.com/search?q=265%...hrome&ie=UTF-8
Just keep in mind the 35 profile is very low so the ride will likely be rougher. I personally am riding on 255/40/18 and like it, but to each his own. Also you mentioned finding a pair - so just two? If so, remember you probably aren't going to be rotating your tires unless you are going wide in the front and narrow in the rear???
<div style="text-align:left;">I should say a set. I found it off a 2004 TL that got rear ended. They’re in really good shape, only thing I will probably change is the color as they are the plain silver not the gun metal. I like the gun metal color but I also really like this bronze color I found when I was looking at getting them powder coated</div>
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
