RDX 19" ACCESSORY WHEEL on 5AT TL
#884
TL Type-S
i see some people put 15 mm spacers.... But i also read some did 15 infrotn and 20 in the back... What is the best option?could someone confirm if 15 all around is good or the other option with these rims? Also car is stock, so no drop (yet)
#885
You can really do either setup. I personally had the 15 front, 20 rear setup until I swapped out my tires. I went from 235 Nittos to 245 Continentals and I was rubbing like crazy with just an aspec drop. Therefore I swapped the 15 mm to the back and I have another set of 15 awaiting installation for the front.
#892
Chapter Leader (Midwest Region)
Where did you all get these. I tried looking on ebay, but I never saw any sets as cheap as some of you picked them up for. Also looked on some OEM parts places and they are still 300 or so apiece.
McCollins23 (04-28-2012)
CLtotheTL32 (09-02-2012)
#903
White ftw
07tl-s6spd (09-02-2012)
#907
Are you at stock camber specs after the drop? Do you think with 235/35, rolled fenders, and 25mm spacers, you'd have the same clearance you do now?
I'm planning on ordering both spacers and wheels today, but we'll see what happens.
The flush thread states that will work for sure, but I want my camber back at factory specs after I drop it 2" or so.
RDHORSE (08-04-2013)
chapu08 (11-07-2014)
rockyboy
01-25-2016 06:00 PM
