A quickie for those with Koni's and H&R
Old 05-13-2012 | 09:38 PM
umakemekissu's Avatar
so I'm putting on my Koni's yellow + H&R springs. for those who have/had this combi what is the dampening adjustment for both Front and Rear to give a luxury or close to stock feel?
i understand it's all about personal preference and i would probably need to go back and adjust several times to fit my taste but just wanna try to make it close the first try...
thanks a bunch!!!
Old 05-14-2012 | 12:24 AM
anx1300c's Avatar
I'm at 1/2 turn from full soft on the same setup and it's pretty smooth, yet still handles very well with the Progress RSB. I keep meaning to play with the settings after a year, but I don't see the need to really.
umakemekissu (07-11-2012)
Old 07-11-2012 | 12:48 AM
Fatfrii's Avatar
i have koni/eibach and 5/8 turns in the front and 7/8th turns in the back give a very smooth ride. well balanced and easy to control past the limit. both my sway bars are solid so if yours are stock you might be able to go a little softer without ur chassis feeling like its being tossed around
Old 07-11-2012 | 10:22 AM
so i just finished the installation last weekend and currently have the rear 1 full turn from full stiff. i keep the front the way it was shipped.
the feel is pretty close to stock feel, a little bit on the stiffer side but i kinda like it. might play around with the front dampening to make it a little bit stiffer cuz i want less body roll on turns.
Old 07-11-2012 | 12:16 PM
ebelp's Avatar
2014 Jeep SRT
Since you're putting on springs that are stiffer than stock, obviously, the softer you can go on the Koni's, the more it's going to feel similar to stock. When I had my Konis + Neuspeed, I kept it on full soft and it was near stock, but still a little firmer. I loved it. Remember, you're "upgrading" your suspension with these new parts, so nothing is going to ride exactly like stock.
Old 07-13-2012 | 05:11 PM
kolgjeraj07's Avatar
Koni and H and R springs
I have tien ss damper coils on my tl. I was thinking about getting the koni and h amd r setup. I want the car to really handle? How is the koni and h and r spring setup handle around the corners?
jblessing
08-08-2018 09:43 PM
CLsuperhero
09-23-2015 12:53 PM
Quick Reply: A quickie for those with Koni's and H&R
