Questions about A-Spec w/ OEM Suspension
How may I help you.....?
Ok guys, need a little help here. I have purchased the A-Spec springs for my ride, but as of right now, I still have the OEM shocks. I searched around and only found a few comments on this.
Are there any issues or concerns with using the A-Spec springs with the OEM shocks? The assumption of course is that they are both technically OEM so one would think they would work together. Just trying to make sure this is OK...
Thanks in advance for the help...
You never want to change your springs and not change your shocks.
First of you, you will not achieve the optimum performence aspects you're looking to achieve.
Second, you will cause you stock shocks to fail prematurely.
Third, if you're in there doing the springs, it would be nuts to not do the shocks as the same time. It's kind of like changing your timing belt and not doing the water pump.
nuldabz
09-03-2015 05:49 PM
