question on spacers
Old Apr 10, 2010 | 10:50 AM
jrtls03's Avatar
question on spacers
ok dumb question. a 5mm spacer on wheel with +45 offset makes the wheel +40, correct? just wanna make sure I have this right.
Old Apr 10, 2010 | 11:21 AM
Turbonut's Avatar
That's correct.
Old Apr 10, 2010 | 11:57 AM
fd2 si's Avatar
8th Gear
what the ^^ op said..
jrtls03's Avatar
Originally Posted by Turbonut
That's correct.
Thanks. Can I use factory lugs with a 5mm spacer or would I need extended lugs
Old Apr 10, 2010 | 12:10 PM
TheDanger's Avatar
2007 TL
you should be fine with stock lugs. why are you only doing a 5mm though? +40 offset on stock wheels is still going to be stuck in.
Old Apr 10, 2010 | 12:32 PM
jrtls03's Avatar
I've got the 19' rdx wheels on 245's with a 1.5 inch drop. I'm worried about rubbing with a 10mm spacer
Old Apr 10, 2010 | 12:56 PM
TheDanger's Avatar
2007 TL
ah. 245's are pretty wide. you should still be able to easily pull off a 10mm spacer with a little fender roll.
Old Apr 10, 2010 | 01:11 PM
jrtls03's Avatar
Yea don't wanna roll the fenders. I think 7mm would be perfect but can't find
Old Apr 11, 2010 | 07:08 PM
jrtls03's Avatar
Are the extended studs easy to swap? Seems like most don't come with them already attached
Old Apr 12, 2010 | 03:41 PM
jrtls03's Avatar
I know most on these boards hate ebay but what do think of these spacers?
http://cgi.ebay.com/ebaymotors/HUBCE...Q5fAccessories
Old Apr 12, 2010 | 04:08 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
the spacer I would trust, those wheel studs I would not
Old Apr 12, 2010 | 06:08 PM
hatchconversion's Avatar
thats not right it makes it +7.5 haha jk yes thats correct.
Old Apr 12, 2010 | 06:53 PM
killersrt's Avatar
The only question I have, is that if I have to use spacers, should I just use the two up front, or should I buy four and put them in the back as well?
Old Apr 12, 2010 | 07:17 PM
jrtls03's Avatar
Good to know. What are good extended studs to buy? Thanks for all the help
Old Apr 12, 2010 | 07:20 PM
jrtls03's Avatar
I'm planning doing all 4 wheels......
Old Apr 13, 2010 | 02:35 PM
KamoteQ's Avatar
I'm looking for some good hubcentric spacers as well. I prefer the 5 mm so that I don't have to change the lug. Any recommendations? Thanks.
Old Apr 13, 2010 | 03:11 PM
myron's Avatar
5mm hubcentric spacers with built in lugs? I don't think anyone makes those. I can't imagine them being all that safe. And none of the 5mm ones will be hubcentric I think. Even some 10mm aren't hubcentric.
Old Apr 14, 2010 | 10:00 AM
TheDanger's Avatar
2007 TL
This site will make whatever size spacer you need. Also they are hubcentric and can even make them wheel centric to aftermarket wheels.
http://www.motorsport-tech.com/wheel_spacers.html
Old Apr 14, 2010 | 03:42 PM
jrtls03's Avatar
Will check them out. Thanks for the info!
Old Apr 16, 2010 | 09:05 AM
jrtls03's Avatar
how hard is it to swap OEM studs with extended ones? is it a big job?
Old Apr 16, 2010 | 09:54 AM
myron's Avatar
I think there is quiet alot involved. I know a shop asked 150-200$ to do it and they themselves told me not to go through with it.
Old Apr 16, 2010 | 10:08 AM
jrtls03's Avatar
guess I'm better off spending the extra $$ to get the spacers with them built in..
Old Apr 16, 2010 | 10:35 AM
killersrt's Avatar
I've replaced studs in a few of my previous cars, and it was never an issue. I wonder what makes this car such a pain
Old Apr 16, 2010 | 10:45 AM
mglax13's Avatar
New shoes on my
I looked into replacing the studs with my old wheels and I don't recall the specifics, but it wasn't as easy as you would think. I'm not sure if it was the front or the rear, but the studs wouldn't come strait out the back because there was something in the way so you needed to like remove the whole hub or something...again, I don't remember the specifics, but it wasn't as easy as it was in older honda\acura models.
Old Apr 16, 2010 | 10:53 AM
killersrt's Avatar
My 240's were like that too, but all I had to do was rotate the assembly to a certain spot. There was place that was notched out, so you had to do one stud at a time and it barely fit, but I would hope Acura would have a similar design. Then again, they seem to have made everything difficult on this car
Old Apr 16, 2010 | 11:03 AM
mglax13's Avatar
New shoes on my
Did some more research. It appears that the axel shaft gets in the way becasue it bulges out a bit and keeps you from pulling the studs straight out. You don't want to jam the new ones in at an angle either becasue you will mess up the threads on the stud.
To get the studs out, you need to need to remove the calipers, the spindle nut, brake disc retaining screws, then remove the hubs. Then you need to press the studs out.
Old Apr 16, 2010 | 11:05 AM
killersrt's Avatar
Fail for Acura
Old Apr 19, 2010 | 06:39 PM
jrtls03's Avatar
another dumb question; if I go through with adding the spacer and changing the studs, will the stockies fit when I put them back on for the winter or do I need to swap the OEM studs back in?
Old May 4, 2010 | 06:46 PM
jrtls03's Avatar
so it seems from searching that I don't need extended studs if I use a 5mm spacer but do i need to use open-ended bolts?
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rboller
Sep 23, 2015 02:49 PM
