A question to modders about spare tires
I saw a custom van with rims and a matching spare rim on the back. Do you TLer's with rims have a matching spare rim or do you have the donut that comes with the car. I assume those of you who lower your cars have a regular size spare.
LIST/RAMEN/WING MAHSTA 짱
A "matching" full size spare would be ideal, but not practical, as Turbonut stated. You wouldn't be able to fit it in the spare tire compartment, either.
Then, you also run into the issue of making sure the spare has even tire wear to match the other four tires that are being run. This used to be done when tires used to be cross-rotated, but not anymore.
If the diameters are different and the flat is on the front, put the spare on the rear and then the rear on the front, that is providing they all the full size tires on the car are of the same diameter. This way it will take the wear and tear off the drivetrain esp. with a limited slip diff.
also just as a note, if you upgrade your brakes to the brembos OR get a BBK, it's advisable that you invest in the TL-S spare tire so the spare can clear the caliper. Also it's good to keep a screwdriver or something of the nature handy to pry off a hub ring adapter if the bore on your new wheels isn't the same as the old ones, otherwise you won't be able to get the spare on with the adapter still on the hub.
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
