PZero Nero M+S Question
Is this tire asymetrical, meaning is it mounted with a certain side facing outwards/inward? Is it labeled this way on the sidewall?
Team Nighthawk Mambo King
Originally Posted by HEK
Actually the tires are labeled Inside outside in a few diferent languages, just got mine delivered and was asking myself the same question so I decided to read the sidewalls and found these markings....I will be standing right there when I get these put on the rim to make sure they go on right....
Steve
HEK.....for the life of me, I can seem to find the markings. Can you give clue to the location of the markings? Tread edge...rim edge?
Maybe I need to get my eyes checked
Take your time and look at every inch along the side wall, you will see it and if the word "inner" is there facing you , you have your tires mounted "wrong"....good luck....
I just went through this process.
The installer mounted all 4 with the 'Inner' facing out.
I brought them back and had them switched.
On my set of 4, P Zero Nero M&S, it does NOT say 'outer'. But as noted above, it clearly says 'inner' in 4 languages.
OK, finally saw the words "OUTER" along the outside edge. Last of several languages as noted.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
