PSA: nib18x8 OEM A-specs for $399 shipped
#203
#204
While in far from a wheel/tire expert (as many here appear to have much more knowledge than I do), I'll say this- I personally installed those Sumitomos on an Accord this summer (yes, I mounted and balanced them) and drove the car for ~15-20mi and found the ride quality to be excellent, road noise was hardly an issue and the price was extremely competitive.
I paid $98/tire for the 245/40's. I currently have Nankang NS20's on there now which I think are also excellent tires for the application (and cost). I took a chance on those and am very happy with them.
I don't expect any issues with the Sumi's
#206
I'm glad you guys have had better luck with Sumi. I think they are crap. After running two sets of Sumi's I was done after mediocre handling in wet/dry (Florida rain), premature wear and road noise.
J- I like the 8.5's because you can run a bigger tire and because of the "exclusive" gun metal color that was only offered in '04.
#208
but the PSS are twice the price of the Sumi's
#209
oh I totally agree...if I didn't have the 8.5's already I would have jumped on these too. It was a fantastic deal. Imaginary rep points (system we used to have on AZ) to the OP.
The following 2 users liked this post by ggesq:
EvilVirus (01-22-2016),
rockstar143 (01-21-2016)
ggesq (01-21-2016)
#212
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com <--- Link
Comparing the differences in the OEM 17" wheel/tires to 18", I see that the 255/40/R18 or 255/35/R18 tires are suggested to fit "rims" with a width range of 7.5" - 9.5".
If this site is relied upon, found link in another thread, where I'm pretty sure a mod provided the link, what's the debate on these two tire sizes on the ability to perform better (winter/snow aside).
Tire diameter:
255/35 --> Shorter (9mm)
255/40 --> Taller (17mm)
Sidewalls:
255/35 --> Shorter (17mm)
255/40 --> Shorter (4mm)
Speedometer:
255/35 --> 1.3% Slower (60mph on odometer is more than actual)
255/40 --> 2.7% Faster (60mph on odometer is less than actual)
Revolutions per Mile (correlating ratio of same height differences):
255/35 --> More +11.2
255/40 --> Less -20.5
So, performance wise, which would better aid a very spirited driver.
I'm leaning towards dedicating a set of max performance tires, please don't suggest a tire, just an analysis of the differences above. I've pretty much already decided on a Summer tire, and will likely go with XL just as I did for my 17" Pirelli tires, because I prefer a stiffer sidewall and the benefits I feel that come with them.
I really think you guys are overestimating the opinionated negative aspects of tire diameter or overall height, so long as they're all the same diameter.
EDIT - I've looked into the 255 debate on 17" wheels, and the originator of that wasn't really after performance and others as well seemed to go that route due to looks and/or supposed rim protection.
Comparable pics from the link above are below:
255/35:
255/40:
Tire diameter:
Sidewalls:
Speedometer:
255/35:
255/40:
#213
Easiest method is to go to TireRack and get the information.
#214
I'm leaning on 255/40 for being slightly taller overall and under the magic 3% to OEM ratio.
It will:
-- fill out the wheel wells a little bit and close more of the gap on an A-Spec suspension (06 AT on MT 08W60-SEP-201B).
-- slightly beefier sidewall, closer to the 17".
-- less revs
-- either should really provide better handling and breaking than the current 235/45R17 I have.
Speedo diff is kinda moot imo:
255/40 @140mph odometer = actual ≈ 138.18mph
255/35 @140mph odometer = actual ≈ 143.64mph
Neither are marginal differences or detrimental imo, even with the 2.7% edging closer to the 3% opinion.
*Note the above speeds are noted to further denote the perceived extremes.
It will:
-- less revs
#215
I find that if you can buy a tire that was made for a specific car/reason, you can get more bang for your buck. For example, the Bridgestone RE070 that was made for the old STi, or the Yokohama A048 LTS that was made for the Lotus, or the Bridgestone S02 that was made for the S2000. These type of tires have been tweaked to get the most from a specific car, but using them on a similar car can have fantastic results.
#216
I take it you're not part of "innacurate's team 255 club," lol?
#217
Forgive me for saying so, but most guys simply don't know any better. I've had the HTRZ and the HTRZII in the past, and they are great performing tires for the price, but they certainly aren't great tires, and it's the only tire that Sumitomo has that's worth anything .
I just learned that you have to pay more to get a better tire
#218
Found this thread, with these pics of the A-Spec wheels members herein recently purchased, on what I assume is a true A-Spec '05 TL. I think it looks great and would fit my performance needs:
https://acurazine.com/forums/tires-w...-tires-600683/
Believe that made my mind up.
#219
I know, right? It's funny how that works. Had I not bought a used set of wheels years ago that already had some super expensive Michelin Pilot's on them, I might still be in the dark.
The following 2 users liked this post by VisualEchos:
ggesq (01-21-2016),
#220
Bridgestone Potenza RE970AS Pole Position
Goodyear Eagle F1 Asymmetric
Capital UHP (not afraid to test a tire out ; but these were thrown in the trash - great dry traction though)
Pirelli P7 Cinturato Plus & XL
All on the stock 17" wheel and recommended tire size.
All were outstanding tires as I wasn't expecting winter/snow performance and have a dedicated vehicle for those days, as many others do. And, so far in my trials of matching tires to the TL, the Pirelli tires I've raved about in other threads fit the TL the best imo and in relation to my aggressive and spirited driving style (mind you Spring thru Fall); key to remember though is the Plus designation and that they're XL rated.
I found out this great pairing, because again, I don't mind experimenting tires rather than always follow the herd.
I've never cheaped-out on tires, save the experiment with the Capitals...on any vehicle I've owned in the last decade.
I don't care to spend upwards of $200-250+ on a single tire any day of the week, so long as it fits my needs.
First thing I did when I purchased the car was put on the Pole Positions.
I've come across posts in other threads where you don't hide your disdain for all-season tires:
https://acurazine.com/forums/tires-w...choice-932212/
In essence a max performance summer tire is seasonal compared to extreme performance summer. I mean come on. Unless you're running extreme performance summer tires on all your vehicles, foot in mouth.... The Michelin Pilot SS are max performance, hence a blended tire and close in performance to some UHP tires...come on man.
Exactly how are you handling the rain if you're running a truly dedicated Summer tire (extreme)...I personally would prefer to not have to slow down . As again, extreme performance is the only true dedicated summer tire and TireRack only has 9 available and all are sub $185...wouldn't mount ANY on my car.
MANY members greatly enjoy their well paired UHP A/S tires...and get into an SUV/AWD during snow days.
In my opinion, the only true dedicated tire are those with a mountain and snowflake designation.
Per the lauded experts at TireRack:
Extreme Performance Summer
You want extreme dry street performance and are willing to trade some comfort and hydroplaning resistance to get it.
Not to be driven in near-freezing temperatures, in snow or on ice, or at high speeds in deep standing water, these specially tuned tires combine big-block tread designs with aggressive tread compounds and reinforced internal constructions to emphasize dry road response, traction, handling and high speed capabilities for serious driving enthusiasts.
Max Performance Summer
You want an unsurpassed blend of dry and wet street traction and handling and only the finest will do.
Not intended to be driven in snow or on ice, these technologically advanced ultra low profile, high speed tires combine computer developed designs, and unique materials with precision manufacturing techniques to provide an unsurpassed blend of dry and wet traction and handling.
Ultra High Performance All-Season
You want all-season versatility (including light snow traction) and are willing to trade some dry and wet traction and handling to get it.
Branded with the M+S symbol, these ultra low profile tires are designed to provide year-round traction (even in light snow) through tread designs and compounds that remain more flexible in the cold weather to help blend all-season traction with very good handling and high-speed capabilities.
Grand Touring All-Season
You want all-season versatility (including light snow traction) and responsive handling along with noise and ride comfort.
Branded with the M+S symbol and capable of providing year-round traction (even in light snow), these tires are designed to blend a performance tire's appearance with a passenger tire's smooth, quiet ride. Grand Touring All-Season tires are often used as Original Equipment and place more emphasis on handling and high-speed capabilities than Standard Touring tires.
Like you said, we all have different needs/wants/desires in our tires, but to discount A/S tires altogether is pretty short-sighted. A LOT of members track on UHP tires...
#221
It will:
-- less revs
-- either should really provide better handling and breaking than the current 235/45R17 I have....
It will:
-- less revs
https://tiresize.com/speedometer-calibration/
Also, keep in mind that for '04-'06 TLs, we have the lawsuit where Honda/Acura gave a 5% credit to the warranty mileage because the speedomter was proven to read up to 5% high. (Mine is actually ~ 2.5% high with stock wheel/tire size, so theoretically if I run 255/40/18's my speedometer should match actual speed.)
#222
Michelin Pilot Super Sports...nothing but 10 ratings EVERYWHERE!
Monkey...if you need the traction or like the looks, I guess so...to me, a TOO bubbly tire can make the rim look smaller.
shiet, just going 225 to 235 I was pretty disappointed with the cornering...although might be a softer sidewall tire.
#223
Like I said earlier, I'm going with the 255/40/18 size, probaby Comp-2 A/S for my non-winter setup. I'll use a dedicated winter/snow tire for winter, not sure what size I'll run yet...
^^^ Isn't that backwards? For 255/40/18 vice stock 235/45/17, 140 MPH on the speedometer would be 143.9 MPH actual...
Thanks for the info about the mileage discrepancies in 04-06 TLs, further confirms my decision. Not that I'm looking for confirming bias.
I'm looking at a blended performance summer tire (max), I certainly don't regard it being truly dedicated for Summer other than that they'll be coming off next Winter. It's not the truest Summer tire, but it is certainly the sanest.
I'm looking at the Michelin Pilot SS, currently there are three available in 255/40/R18 and I'm only interested in the XL for stiffness...I despise sidewall flex. Please don't slob on the knob regarding these tires, it'd be enough to turn me off of them. If I can't find them, or don't go in that direction, I'll likely be back in a Pirelli.
The two XLs listed are $228.75 (special) and $239.75 (stated as new). Comparisons of the URLs alludes that the latter is "V2," which I assume is version 2 for this line of their max performance Super Sports.
Not in a hurry, will likely wait on a rebate between now and Spring to jump on them.
EDIT - Ditto on next year dedicating a true snow tire, I'll likely keep my stock and new 17" wheels and keep 235 for snow.
#224
I think the XL makes a world of difference, any limits you're testing are truer and quicker in response...stiffer sidewall.
A few of you have seen the curves I've posted about around here . Yes, traction please.
The wheel in the above pics doesn't look small in any way in my opinion, maybe for stock height guys...dunno. The setup in those pics look perfect!
VisualEchos (01-21-2016)
ggesq (01-21-2016)
#227
I like a tire that turns in very fast (it helps nullify the horrible understeer most companies program into their cars), has a very stiff sidewall, and breaks away progressively. I don't care about tire wear at all, if it lasts 3,000 miles I'm good with that, because I understand that the brightest star burns out the quickest, hence the R888's, A048's, and A005's being my favorites. I suppose "feel" would be my defining factor in choosing a tire, and I understand that I would be different from most in that regard. This doesn't change the fact that all-season tires suck tho' .
Please enjoy your all-season tires, it's no skin off of my nose . You could always come drive my Exige, might just change your mind .
And PLEASE remember that tires are the single most important performance enhancement or detriment that you can do to your car! -Bob Bondurant
ggesq (01-21-2016)
#229
I get that you enjoy your Exige, seems to be a great choice for an cheap weekend adrenaline car. I don't consider it exotic by any means, cool for sure, but not exotic or lusted after.
I personally would've went with a GTR or something similar in adrenaline, if money was no object since buying tires every 3k appears to be a sensible financial decision for you. Or an Audi R8...quit burning money on tires and you can step up to a true exotic.
Top three for me are:
Tires
Brakes
Lights
#230
For the record, I never said the car was an exotic, or that I purchased it for lust. I purchased the car because it moves like no other normal car in the world, exotic or otherwise. To get a better driving feel you'd need to go with an Atom, 340R, or Caterham, and they're a bit too far on that end of the spectrum for my taste. The other reason I purchased the car was for photography, and to that end, very little compares.
The Golden Rule. by Andrew Thompson, on Flickr
#232
I'd hate to think about the time you spend in photoshop and editing out the boom in your shots.
And I can think of several cars that are more camera friendly, photoshop or not.
It is a cheap car. It's a car that only a high school student would break their neck looking at it. It's inexpensive, there, that better?
I'd consider the RLX or even a 5 series BMW more exotic than the Lotus.
The Lotus has always reminded me of a crotch rocket with an outer gimmicky shell...looks like the silly 3-wheel thing Rob Dyrdek drove on that show of his. Laughed my ass off at the guy in the Bull Run driving your "exotic" car. Sorry, it's not.
It seems you can come across as a little more haughty than you should. Yep, that's the word.
Opinions are like assholes, some smell more than others.
EDIT - Congratulations on your car brand (Lotus) coming in just ahead of the RX-8 for the best handling cars under $100,000. At least per the geniuses over at Car&Driver.
#233
(Putting moderator hat on) enough with the insults monkey trucker.
The following 3 users liked this post by ggesq:
#234
#235
You guys really nerded out trying to outsmart each other on tires.
The lotus is a poor man's exotic, IMO but only due to cost...and yes. Buddy of a friend, Law had a red one that was supercharged and MAN that thing was fun to look at.
I would love one.
Anyway, y'all got me thinking of getting those Michelin's...although with the way I like car to sit, I likely would stick with stock tire sizes.
I would love one.
MonkeyTrucker (01-22-2016)
#236
And for the record, it doesn't take that long to edit the boom out of a rig-shot, and in any case, the results are certainly worth the time spent.
Wicked Sensation. by Andrew Thompson, on Flickr
#237
Again, enough with the insults.
Do we really need to close this thread and hand out bans?
The following 5 users liked this post by ggesq:
cu2wagon (01-22-2016),
MonkeyTrucker (01-22-2016),
nfnsquared (01-22-2016),
thoiboi (01-26-2016)
The following 2 users liked this post by rockstar143:
ggesq (01-22-2016),
#239
VisualEchos (01-22-2016)
#240
Protective vinyl removed, center caps/emblems nice and tight... Going to lay a nice thick coat of wax all over the wheels this weekend. While I love snow, not being able to install these wheels is killing me!!!! Arrrrggghhhhh!
