Plastidip wheels on 3G TL????
Posted this in 4g instead of 3G!!!!
Hey all new member, finally got a new TL, the 2000 TL is no longer!! 250k and trans went...I have done a few mods to the new 2004 TL, will post pics after my 5 posts!! Looking to see if any one has pics of TL with plasti dip wheels, looking to change the look of the car, need to save up for new wheels...
Registered 3.5L Member
It'll look good for now..but think long term...
Not a fan.
Look forward to seeing pics of the 250k TL though!
I would think any coating would offset the balance of the rims and it may be a pain in the arse to get wheel weights to stick
If you REALLY want to do something like that I would look at rhino lining or one of the other brands that they use on truck beds I think you can get different colors and smooth finish. It would last a very long time.
Thanks for all the advice.. I decided to paint the wheels gunmetal dupli color.. Came out really good!!! I will post pics soon, as well as the last picture I took of my 2000 TL before it died...
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
OP congrats on having the wheels redone! I'm in for pics
![Popcorn](https://acurazine.com/forums/images/smilies/popcorn.gif)
Engine cover ![what](https://acurazine.com/forums/images/smilies/what.gif)
Both cars are clean! The 07-08 stockies look great on the 2G.
Had to do a lot of sanding!! All the wheels had crazy curb rash.. Had to prim the wheels, 4 coats of paint, and 3 coats of clear.. I hope they don't chip!!!!I will post pics on car soon..
94 DC4 RS LSV/Turbo
if you clear plastidip you wont need to reapply every so often, with 3 coats of clear hell that is more than what you get out the factory... you'd only have to worry when you get new tires
Yes Duplicolor, sanded the wheel first with 80grit, 120, than 400grit, primed the wheel, 4 coats of paint, 3 coats of clear coat.. give the coats about 10 minutes , and hit it with another coat, letting the wheel try to much or not enough can make the wheel dull, or rough looking...Hope that helps...
Engine cover seems to have stired up a lot of conversation. I wanted to paint the cover a different color than the rest of the plastic...I had a hard time finding colors to spray the cover with that could take the heat of the engine, so I used engine paint, not a lot of color choices!!!
Srhayden21 (09-11-2011)
I'm not a huge fan of the blue in the centercaps BUT it matches the other accents on your car, so I applaud you for that
Paint job looks really good...
Paint brush and a steady hand!!!
Still not sure either...I put blue lug nuts on, and painting the calipers blue as well.. Will see...
dont copy my car
lol jk man, wheels look good!
![Name: IMG_7938.jpg
Size: 49.9 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/51817d1501290764-plastidip-wheels-3g-tl-img_7938.jpg)
JByron
01-08-2016 09:49 PM
