pirelli Pzero's PSI?
2004 TL
I have had these tires a while and im unsure that to keep the psi at.
For those of you with these tires, what do you keep the psi at.
I had the EL-42's and they sucked and had the fronts wearing down. Before I left for school in MA I switch to the pirelli's and have no complaints. I also kept the back two tires because they were fine. Just want to know what the best psi is for these on this car.
Its and 04 TL btw
Its and 04 TL btw
Well, I have just got them and for now, I'm keeping the fronts at 34 and the rears at 33. I don't know if I'll have to change them after I install my CT RSB.
I'll experiment more when the weather breaks. Although we are having a warm winter here in NY.
2004 TL
if im correct the max for them is 51. Mine are at like 32 now. Just want to see what i should leave them at. Driving in NY and MA. I live in NY and go to school in MA.
Gratis dictum
Regardless of the tire I would keep 10% higher pressure in the fronts than the rears. For thr Pirellis, I would go with 37 in front and 33 in the back as a starting point. You can then experiment from there.
Anyone running 18" w/ pzero M/S? What are you guys doing for PSI?
I've been running 39/36 per factory spec, but looked at my front/rear wear pattern and fronts were wearing out to the 2nd most outer wear nubs, with about 50% of the 2nd row of nubs still there. Rears had a full 3 outer sets of wear nubs with almost 100% on the 3rd ring. I suppose this might be due to fronts taking more of the cornering force and that this is why you rotate your tires, but wanted to see what other's experience has been.
I notched my rears down 1 PSI to 39/35 so we'll see how that feels tomorrow.
信是寶
Its and 04 TL btw
Its and 04 TL btw
Just make sure you check them on a regular basis when cold ... psi fluctuates with temperature.
As far as how long they last ...really depends on your driving style.
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
