People with Koni SP3s/Neuspeed struts
For those that have the Koni SP3's aka Neuspeed struts, what perch are you sitting on and what does your gap look like? Do you have a camber kit? If no, should you have one? If you could post a picture, that would be great too.
I'm getting these installed on my car with Eibach springs this week. I bought them used for 260HP and right now, the little ring is on perch 3:
Please use the following perch numbering scheme when responding:
Herro
I'm on lowest perch (1). I have almost no wheel gap (about maybe....an eighth of an inch gap) or so. No camber kit, my front tires are getting worn, but my rear is holding off pretty well for now. I should get one soon. Pictures will come later as I'm posting this during school.
Neuspeed Accord Springs btw.
^ Hot ride! Exactly what I've been looking for.
So thats a little too low for winter I think. I'm thinking:
Front perch 2
Rear perch 3
I notice you have a little rear sag, even though your rears are at a higher perch... is that common? Or do you just have a massive system?
Front perch 2
Rear perch 3
Retired!!! ON TOP!!!
Yeah... Alot of Junk in the Trunk...
... but the way the car is designed... the wheel well arches/radius are cut differently... the rear radius is smaller than the front... so it gives the illussion of the rear sagging... but I'm actually even cause of the JUNK... LOL
Chill_dog
Naw... I got those wheels in November '07... but they sat through the winter and installed in April '08... I don't typically start new threads on my stuff... they usually get leaked out by other members...
... so no... they are't new... but they are for SALE...
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
Chill_dog
RIP Dime...
It's going to depend on what springs you have. I have the perches set at 3 in the back and two in the front and I'm pretty low with the neuspeeds on there. I hope to move to something else next summer. I pretty much have no gap in the front and about 1 finger in the back.
Here's a couples pics![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
![](http://i144.photobucket.com/albums/r182/ryeemo/DSCN0912.jpg)
![](http://i144.photobucket.com/albums/r182/ryeemo/DSCN0913.jpg)
Hey Jason. The shocks have the perches at their stock location. Meaning the shocks are delivered new with the perches at that location, which are the middle (3). They pretty much match the stock shocks.
Keep in mind, my car was 6MT so its front end is lighter by quite a bit. When I was running Prokits, I lowered the front spring seats to the bottom (1) to eliminate the sagging look. Well, I didn't have other options back then because I paired them with the regular Koni Sport.
Later I changed to H&R Sport and Koni SP3. I lowered the front spring seats to the #2. The car looks almost identical compared to my old Eibach/Koni Sport setup.
Like I said in the PM, it's easiest if you just measure your car's current height. Measure the distance from the highest point of the fender to the hub's center. Do it on all 4 corners. Then, you can tailor it to whatever you want. If you want to lower the front end another 1/4", lower the spring seats to the next lower point (2). Each spring seat position will change the ride height approx 1/4".
I assume the bump stops are not cut. If they are, your car may sit lower than what Eibach specifies.
Oderint dum metuant.
Chill_dog
MrHeeltoe
20
02-23-2023 01:54 PM
ITSJESTER
17
12-06-2018 02:29 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
