part numbers for top hats
hey does anyone happen to know the honda part numbers for the front and rear upper top hats, rather than swapping them over from stock suspension, or from ordering elswhere i can just get from my local dealership.. Thanks in advance!
alright well i think ive found the part anyways, but when swapping suspension out for new coilovers, is it just the top mount that require being swapped? and maybe some washers... also is it required to compress the spring when removing the stock suspension if i dont intend on taking it apart??
05' AT SSM
Bump....
I'm about to pull the trigger on some coilovers and was wondering what other supporting parts we need to make this an easy swap. I imagine odishaw is done with this but i'm still wondering, i know we don't need to compress spring if we use new top hats and accessories.
Just not sure what part numbers we need to order for this to be an easy direct swap without dismantling the oem setup.. any info is greatly appreciated.
Front:
![](http://i9.photobucket.com/albums/a89/KZOOPWNER/typesshocks.png)
Rear:
Front:
Rear:
![](http://i9.photobucket.com/albums/a89/KZOOPWNER/ImageStreameraspx.png)
Marcus at Heeltoe has them. Type in acurazinerocks for 5% off. That's all you need. The type-s ones are firmer than the stock TL ones.
http://www.heeltoeauto.com/home.php?cat=465
robocam (04-28-2014)
