Only want to lower it an inch.
i cant lower it anymore i live in pothole city, so iwas thinking of only an inch to help fill up the wheel wells. im thinking just springs for the price and simplicity. any other ideas. the less i spend on lowereing the more i can spend on rims. thats why i was thinking just spring as per coil overs
DRINKING HAS A ME PROBLEM
there are benefits still to go for coilovers. dampning, you can raise it back up in the winter if needed. or lower it if you are going to be away from the pot holes for a while.
Registered VTEC junkie
Just do it right and get the A-Spec suspensioin. If it's just an inch you want, the A-spec is perfect! Also, the kit has matching shocks. Pairing up stock shocks with aftermarket lowering springs/coilvers will only wear the stock shocks faster. Eventually, you'll need to buy new shocks.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
