Offset for AT Italia S5?
Does anyone know where I could find the offset for the AT Italia S5 18x7.5 rims? I'm experiencing rubbing w/ these wheels & springs, and I want to see if it's the offset that's causing the problem. Thanks for your help.
If it's a +50, you shouldn't be rubbing. I was running +48 with 225/40ZR18 and didn't rub with Comptech springs.
May want to check that plastic tab sticking inward at the top of the rear fender well!
That's what it turned out to be. The only rubbing that occurs now is if I take a bump at high speed on the right side - then there's a little piece that sticks out below where that tab was. I've pretty much got to be trying to make it rub though, so it's no problem. Besides, it happens enough, and it'll wear it down to where it doesn't rub anymore - problem solved by being lazy!
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
