Non-OEM Wheel bearing
I have to replace a wheel bearing and wondering if anyone has used a non-OEM one. I was looking to buy the National from RockAuto since they're a pretty trusted brand only thing throwing me off is this one review on amazon saying it triggered his VSA/ABS lights after installation. Is this a concern or is it just another case of some idiot messing up and leaving a bad review? It's listed as "popular" on RockAuto so I figured it'd be fine
Latent car nut
Received 2,005 Likes
OP, the bearing has to be installed properly. Since you reference VSA, I assume you're referring to a front bearing. The brown side with the magnetic encoder has to be installed toward the inside of the knuckle. Page 18-16 of the service manual.
If they installed it backwards (and I've read about it happening), then yes, the system will throw lights and codes.
And why do you have to replace the bearing? It's pretty rare that a wheel bearing needs replacing...
I'm down for a second opinion if you want to give me yours. Car sounds like a helicopter at 40+ MPH even when i'm off the gas, when I curve left the sound is still there but it disappears when i curve right. Everything on the wheels feels tight when I do the wiggle test but i've heard that's not always a surefire method of diagnosing a bearing issue. I've replaced 2 tires that were starting to show wires, swapped front and rear tires, upped tire pressure.
axle joint?
Its probably a wheel bearing. Or cupped tyres.
105K is early for a wheel bearing. But it may have been from some impact at some point in the car's life. Or maybe someone left an axle nut loose during a service, or the axle stub stretched, or you got unlucky and got a defective bearing from the factory, or etc etc. It happens.
Does it spin rough by hand?
I had to take a detour through a neighborhood for about a month due to construction and there were some nasty potholes I hit pretty hard 2-3 times when I wasn't paying attention. Would that do it? It was always on the passengers side
azatabbasov
05-12-2014 09:03 AM
tomf
09-22-2010 10:47 AM
PeterA6
12-13-2006 09:47 PM
SatinSilverTypS
09-08-2005 08:36 AM
