New "modified" TL alignment spec for rear camber??
Old 07-14-2013, 04:37 PM
nfnsquared's Avatar
Received 1,795 Likes on 1,348 Posts
Just had my alignment done at Sears. According to the alignment machine's spec sheet, the rear camber spec has been expanded a bit:
from -1.0 (+/- 0.5) to -1.0 (+ 0.7,-0.8)
Where -1.5 had been the negative limit, it is now -1.8.
Old 09-25-2013, 11:18 PM
unlimited's Avatar
how is the ride after the alignment? any pull to left or right?
Old 10-01-2013, 06:08 PM
Nova_brad's Avatar
Last time I aligned my car my rear spec was -1.8 as well.
"Modified spec" could be manually typed in by the hunter machine
Tech (or service tech or shop foreman for that matter) when he updated the specs manually instead of by a complete software update that would update all the specs with a download.
We would have our hunter guy come in every year to type in all the updates and changes that manufacturers have.
Your numbers look great and shouldn't cause a pull at all.
I miss working in a shop with an alignment rack...
Old 10-01-2013, 10:28 PM
Received 8,751 Likes on 6,750 Posts
I just took my TL-S to an alignment shop and the camber negative limit for the rear was -1.8 as well.
Old 10-01-2013, 10:50 PM
JJH
JJH's Avatar
Our rear ends already fan out under drive load so I went closer to zero degrees. Ended up with -.03 degrees all around. -1.8 degrees is too much IMO.
Old 10-02-2013, 10:02 AM
nfnsquared's Avatar
Ride is fine, no issues.
True, and it's important to load the back seat/trunk with the same load that you normally drive with when the alignment is done.
As long as the rear camber doesn't exceed -1.8 and toe is kept in spec, there doesn't seem to be much an issue with tire wear on the rear. If camber gets more negative than -1.8/-1.9, look out if toe gets out of spec... rapid inside edge wear is imminent...
james357
02-13-2016 02:37 PM
o8 ENVII 8o
11-30-2015 04:23 PM
obsessedmotors
09-10-2015 10:49 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: New "modified" TL alignment spec for rear camber??
