Neuspeed SP3 with race spring
04' tl 6 spd
Does anyone have Neuspeed race spring on there ride. Just wondering if you guys can post some pictures to see how low it would be. I just purchased Neuspeed SP3 with race spring, i want to know if the ride height is to low, bottom out, tire rubbing and ride quality? I also have a set of tein S Tech spring should i switch spring or just run neuspeed with SP3 shocks? HELP
thanks
thanks
Former Sponsor
thanks
thanks
I don't see neuspeed springs for this application specifically.
If you've got the Stechs why not run those? The SP3 are adjustable to suit whatever spring you have!
Also the neuspeeds are going to allow ride height adjustment to get the height where you want.
The ride should be pretty reasonable. Firmer than stock but far from jarring I'd think. The bottoming is more an issue with the shocks than the springs. If you use the correct bump stop (I think the konis come with hard plastic ones) then bottoming is not an issue. If you have stock wheels/tires or properly sized aftermarkets then you won't have rubbing. That is not a lowering issue, its a wheel/tire issue.
Too low.....that kinda depends on where you want the height to be at....
Marcus
04' tl 6 spd
Need help?
honda Accord 03+ Neuspeed race springs Part# 55 20 57 (Front 2.2 inch, Rear 2 inch)
or
honda Accord 03+ Tein S-Tech Part# SKA52-AUBOO(Front 2 inch, Rear 1.2 inch)
Both spring would fit on 3gen TL, correct me if Iam wrong. On tein web 04+ TL same part# but only front 1.3 rear 1.2 inch drop are these the same springs?
I have both set of spring but dont know which to install with my Neuspeed/koni SP3 shocks
or
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
