Need some help from the PRO's about Spring's
Old 09-28-2008 | 07:40 PM
Anarchy919's Avatar
Anyone know what is the difference between the 04 TSX stock Springs #51401-SEC-A03, And the stock 04 Base TL springs # 51401-SEP-A03?
I'm looking for a set of springs with a slight drop and H&R has the ( H&R OE Sport Springs ) -0.75F -0.5R for the 04 TSX but not for the 04 TL
Is it just the Spring Rate's different for them?
Old 09-28-2008 | 07:49 PM
Anarchy919's Avatar
Sorry about that....
Old 09-28-2008 | 09:40 PM
Fulani has a TL's Avatar
Part numbers are the same, meaning it is the same product. What will/should happen is that you will have a bigger drop because of the weight of the TL
Old 09-28-2008 | 10:05 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
^false... if you throw tsx springs on the car you will just have a different spring rate, meaning you may hit the bump stops on dips and prematurely wear out ur struts
H&R makes springs for the tl 50104
if you want a similar drop to the one you stated above than you want the aspec suspension
Old 09-29-2008 | 05:10 AM
Anarchy919's Avatar
I have a new set of KYB GR-2's still in the Box but can't seem to find the Springs with a small drop and do they sell the A-Spec Springs alone? Also can't seem to find the 04 TL stock spring rates anyone know what they are?
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
AcuraKidd
09-25-2015 11:18 PM
Quick Reply: Need some help from the PRO's about Spring's
