Need some confirmation
Just want to make sure these will work before i pull the trigger. XXR 530's in 18x9.75 +20 in the rear and 18x8.5 +20 up front. I am maxed out on tein basics and my fenders are already slightly rolled. I just want to know if these wheels will fit or will i need some crazy modifications to the fenders to make them work? Also, what size tires do you recommend to make the wheels fit best? the lug pattern says 5x4.5 will this bolt pattern fit?
Thanks!
Thanks!
I recommend you check out the threads for the XXR 527. Both wheels have similar specs, just a different face. Lots of information on fitment, such as, camber, tire size, fender mods, and their stance. The lug pattern for the 3G TL is 5x114.3.
I definitely know the 18x8.5 +20 will fit up front with proper fender mod, camber setting, and tire size. The 18x9.75 +20 is pretty aggresive, but I think it can be done. Hopefully another member with more insight can provide you with some helpful information, but definitely check out the XXR527 threads.
justnspace (05-09-2012)
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
09-25-2015 06:14 PM
