Need Opinions on Front Camber Kit
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I'm shopping for a front camber kit for my 05 TL.
My $200/ea Nitto NeoGens were showing steel in under 8,000 miles with the front toe set at dead zero.
Front camber is at -1.7 and -1.9 degrees. I did rotate my tires at around 4,000, but they still wore out. I don't race or drive hard, and my driving is 50/50 city/hwy.
I saw these Skunk2 front upper control arms with an adjustable (slide) ball joint that provides +/- 3.0 degree adjustments up front. The kit costs $285 for both sides at Excelerate Performance.
![](http://d5otzd52uv6zz.cloudfront.net/60a2730f-4a43-42a8-b3e4-b8fc2a87c7a8-420.jpg)
http://store.excelerateperformance.c.../i-290232.aspx
Does anyone have experience with this setup?
Would you recommend something else? What do YOU have?
Thanks in advance for the help. I need to make a move quick. I just spent $400 replacing my front tires and I don't want them wearing out prematurely again.
^same ordering soon. theres a comparison thread floating around between the ingalls ball joint vs the skunk version, the skunk offers wayyy more clearance within the wheel well, and has more adjustability, plus you can just swap it in.
Found it for you:
http://heeltoeauto.com/httech/YaBB.pl?num=1253319665
Found it for you:
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
